Center bore for 6 lug?
Does anyone know what the center bore of the 6 lug bolt patern for our truck is? The reason i ask is because i know the bolt patern is the same as the late model 6 lug trucks but i have heard that the hib is another size and im rim shopping and need to know thw hub size of the older 6 lug patern.
A lot of the newer rims won't work on our trucks because of the back spacing, also. Stock back space (distance from back side of the center hub to the inner bead) is 4-1/2". If the back spacing is much more than that, there will be rubbing on the frame, inner fender during turns. If you are still running drum brakes up front, you may have interference with your steering arm.
Silence is golden, duct tape is silver. - Scott |
#3 | |
Does anyone know the hub size of the old 6 lugs??? ![]() |
Shortbox wanna-be.
So would this be the measurment of the inside hole of the rear drum? Do you mean the flange on the axle that the drum and rim would slide over? If so I have a pair of 6 lug drums laying here I could measure the I.D. of the hole.
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) ![]() |
#5 | |
Shortbox wanna-be.
Yes the hub on the 6 lug trucks is larger than the 5 lug. I just had my 6 lug axles redrilled to the 5 bolt pattern and had the have the center hub machined down so the new 1972 5 lug drums would slide on.
I'll go measure it for you right now. Be back in 5 mins. Reid
Shortbox wanna-be.
OK the center hole of the 6 lug drum measures at a hair over 3.5" so I would think the hub on the axle is probobly exactly 3.5"
If you need it I can measure a new 5 lug axle drum as well. Reid
Steve is correct, the later model six lug rims have a smaller center hole and won't fit on our trucks, I found this out "after" purchasing a complete set of rims.
Just Don't Stop!
![]() Join Date: Feb 2004
You could always bore the wheel and get different center caps. A guy on the board did this to a nice set of Eagle wheels a while back. Not sure how it all turned out but the 20's looked GREAT obviously.
1968 C10 build in process TT LSA/6L90e/9" |
Greyhound, I am currently working on this same problem. I have just ordered 1/2'" spacer off of e-bay. And also ordered lug nuts to fit on 7/16" studs but convert to 14mm so I can use the black lug nut covers that hold the center cap on. I may have to use longer studs?? Otherwise we were going to turn the center of the wheels to 4". When I get the order I'll let you know how it turns out. I converting to 16" rims from a 2003 Chevy. Sounds like alot of good info form above replies, I'll have to check clearance for fender wells and etc... Iman
I have heard from a couple members that you can bore the center hub on the rim to fit and one member told me he machined the rotor to fir. I am going to pick my rims up on Friday and hope for the best. I think i am also going to have back spacing trouble because the rims i got for the rear measure 22X9.5 with 5.682 bsm. I will probably have to use a spacer on these so i would think that might cure the problem on the back rims. The fronts are 20X8.5 with 5 1/8 bsm so they should fit without too many problems providing that i can make the hub fit. Machining the rotors seems like a better option than machining the rims since the price of both rotos was less than 1 rim. Does anyone know if machining down the hib on the front rotors would be a problem?
I just looked at the "center bore" on the rims and it says its 108.20mm. Does anyone know what this means? Repo said the center hub on his 6 lug drums is about 3.5". Are we talking about the same thing here? By my math thats 4.26 inches so i guess that means i wont have to worry about machining anything..... if what i think this means is correct???
#13 |
Heres a picture of what im talking about.
#14 |
Just Don't Stop!
dont' see any pics Steve?
#15 |
OBS guy
I got a set of wheels off of a 99 K1500... They fit. American Racing has 2 part numbers on certain lines- one part for ALL trucks and one part for hubcentric trucks (99 newer) If you want to remove all doubt, get the part number and call the vendor...
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
#16 | |
#17 |
Yep, that would be correct Steve. You shouldn't have any problem with those.
#18 |
From the picture it lists the offset at 10mm. The numbers you listed for back space don't match the pic. If you take the rim width (8.5) and divide it by 2, the offset is from that dimension so your only 10mm from 4.25". Your backspace looks good. Going over 5" as you stated would mean spacers. I know..I'm more confused than ever now.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
#19 | |
#20 |
Just some more useless info - I've got the ECE disc kit on my 70. The hubs on those are 3" + a tiny bit.
Additionally 25.4 mm per inch. Those center holes on your 22's are about 4". GreyHoundSteve - How do your front rims fit? I was under the impression from all of my reading that we can't use a rim over 4.5" of b/s on the front otherwise we'd rub the rim/tire on the inner fender and/or frame. |
#21 |
67-72 parts collector,…
![]() Join Date: Nov 2002
incoma,... I have seen as much as 5.25 in the front (on an 18" rim.) My 17's on the blazer have a 5" backspace on the front.
#22 |
And the 17's don't rub at all? Did you modify your inner fenders at all?
#23 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#24 |
I image you're referring to your green stepside that you sold? I didn't realize you had 17"..
#25 |
I heard from a few members that if you run larger than 16" rims youll be okay with 5"bs so i figure since im running 20's up front i should be okay with 5 1/8 but its just a guess at this point. I am going to go pick up the rims Friday and do a test fit on Saturday. I wont have any rubber on them but it should give me an idea on what needs to be done to make them fit. I will report back on my findings (with some new questions im sure).
