where to buy tranny lines??
i know that i can purchase them from one of the vendors on the board, but i am on a tight time schedule and i was wondering if there are any places like schucks or napa that would have tranny cooling lines. or how hard do you think it would be to make my own.
thanks, 67pro-street |
Should be able to buy pre-flared tubing at NAPA of the correct diameter and length and a good tubing bender (not the spring type). Take an old line with you to compare diameter and fitting size. With a little patients you'll have a new set of lines. Wouldn't it be nice if they sold this stuff in stainless steel though?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I make all my own from parts store lines. After doing it for awhile, I can make a set at least as good as factory ones were.
You want 5/16 line.
![]() Join Date: Sep 2001
You can borrow the tube bender and flaring tool from Autozone if there's one around. I had flexible lines made by NAPA, took 5 minutes and $86 precious dollars.
