Old 12-28-2004, 07:28 PM   #1
dave3156
Need Edelbrock #1406 Carb to pass emissions
Truck did not pass Federal emissions. Technician said the only thing to do is to replace the carburator and set timing. I know my carb needs rebuilt. (it leaks) If anybody has a new or like new carburator I'm interested. Need an Edlbrock #1406, 600 cfm carburator. Also anything else I can try to get it to pass? It failed on unburnt hydrocarbons. Standard is 900, my test was over 1500. Engine is a 350. Runs good. Does not burn oil. Mileage unknown.
dave3156 is offline   Reply With Quote
Old 12-28-2004, 07:34 PM   #2
GreyHoundSteve
Ive seen fuel addatives at auto parts stores that promise that regardless of your engines condition that you will pass emisions testing if you add XXXX. Ive never had to use these types of products but maybe the guy behind the counter can tell you if they work or not. Personally, i always make sure to take my vehicles to places where i know i will pass.
GreyHoundSteve is offline   Reply With Quote
Old 12-28-2004, 08:47 PM   #3
Sonny
Active Member
Do you have a 1406 now? If you do, buy a rebuild kit for $35 and do it yourself. Print out the tech sheet from the edelbrock website: http://www.edelbrock.com/automotive/eps_intro.html and rebuild it yourself. It is very easy to do. The tech sheet will tell you how to tune the carb and give you better pictures to go by when you rebuild the carb. Good Luck!
Sonny
Sonny is offline   Reply With Quote
Old 12-28-2004, 08:52 PM   #4
jay6891
Car Knocker
jay6891's Avatar
I have got a used 1406 in my shop, been siting there for a couple of years. Will need a rebuild just from sitting so long uncovered. I worked well when i pulled it. Went to a 1407, more fun less gas mileage Anyways 50 bucks plus shipping and it will be yours.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
