Road Draft Tube VS PCV
What are the pros and cons of a road draft tube in the back of the block vs a pcv in one of the valve covers or in the oil filler tube?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Fabricate till you "puke"
Road draft.....yea, i remember seeing that so called set up......If I remember right, 61 or 62 was the last of that! there is a good advantage running a PCV system.....keep that oil in the eng! some veiw the pcv system as "early emissions controls".....maybe so, but I feel that the pcv does a lot for the rings(keepin things sealed).....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Watch out for your cornhole !
![]() Join Date: Jun 2003
PCV is all I would use.
You want those nasty fumes out of the engine. A road draft tube was marginal at best. The PCV will keep the crankcase cleaner, the oil will last longer, and the engine won't sludge up near as bad. Your 68 would have had a PCV here in Texas brand new, so I'd definitely assume that your California truck definitely had one stock.
Tx Firefighter
When I got the truck it had the scripted valve covers on it with a pvc in the oil filler tube going to the carb. No breather that I could locate. I like the look of the scripted valve covers but I dont want to mess up the engine. Any thoughts on how I could do this?
One of my friends has a 67 Impala with the scripted valve covers. He had his block drilled and tapped for a 90 degree 3/8 fitting with the pcv in the hose.
The hose is connected to the carb in back so it is pretty well out of sight. The oil filler tube has a filter cap on it to complete the circuit. Jim |
Need to check with some of the car guys but if I recall correctly there is a fitting that goes in the place of the draft tube onthe back of the intake to install a PCV. Saw a 409 set up this way. If they can do it with a 409 I'm certain they can do it with a small block. I agree with the rest run the PCV.
#7 | |
Do you mean a pcv in the valve cover or is there a way to run one where the road draft tube would go?
Here's the PCV adapter that goes where the draft tube was.
![]() About the only good thing about having a draft tube is that you can make the engine idle very slowly. |
So I can convert it from the road draft tube to the pcv. Hmm ok thats intersting. So it wont matter what year 327 I get.
Thanks for all of the info.
#10 | |
Cantankerous Geezer
Fred There is no such thing as too much cam...just not enough engine. ![]() |
member
I have the road draft tube on my 60 sedan delivery. You will need to have a black driveway because they tend to drip an ocasional drop of oil. I believe thats why the change was made.
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
