Old 12-28-2004, 07:53 PM   #1
76bonanza
76bonanza's Avatar
need help quick
see this thread
http://207.44.196.117/vboard/showthr...32#post1065932
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-28-2004, 08:00 PM   #2
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Yeah I posted on the old thread. Sorry bout that man...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-28-2004, 08:05 PM   #3
784X4GUY
784X4GUY's Avatar
Yeah keep us informed about how everythings going for ya. Good luck...Later Mike
Old 12-28-2004, 09:45 PM   #4
76bonanza
76bonanza's Avatar
well got cable on looks ok no leak but it will not downshift either sooo any thoughts I have adjusted it several times should it spring back after throttle returns? it does but not all the way?
1968 c10
lowered 3" 4"
Old 12-28-2004, 10:09 PM   #5
784X4GUY
784X4GUY's Avatar
If you pull on the cable itself does it feel like there is a spring pulling aginst it. Or is it really tight and wont move. There is a spring that holds aginst the linkage in the transmission. I think it should go all the way back in...Later Mike
Old 12-28-2004, 10:23 PM   #6
76bonanza
76bonanza's Avatar
yes there is resitants and it springs back just not all the way.
1968 c10
lowered 3" 4"
Old 12-28-2004, 10:24 PM   #7
76bonanza
76bonanza's Avatar
oh and it will not down shift
1968 c10
lowered 3" 4"
Old 12-28-2004, 10:28 PM   #8
784X4GUY
784X4GUY's Avatar
I have a HRM layin around here somewhere. I believe it says something like there is a little button on the side of the cable up around where it goes through the bracket by the carburetor. Your apost to push that in that lets the cable adjust. Then while thats pushed in your apost to go full throttle with the carburetor, then push the button back in to lock it. I havent done this in a few years so im a little rusty. Try that then let me know what still happening. Good luck...Later Mike
Old 12-28-2004, 10:30 PM   #9
784X4GUY
784X4GUY's Avatar
Oh and I believe if it doesnt spring back all the way then something is interfering with it down where it connects at the tranny. Id pull the bolt back out and have someone pull the cable and Id slide it back into the tranny and reinstall the bolt and then see if you have any binding still...Later Mike
Old 12-28-2004, 11:30 PM   #10
76bonanza
76bonanza's Avatar
What I had to do is put a small bolt and nut at the end of the slider that goes over the throttle linkage so it would pull the cable farther at wide open now it is down shifting I will adjust it some more tommorow it seems the end piece slider thingy is to long? So I think it is snapping back it is just that the slider is to long does that make sense? Think it will be ok like it is? Seems fine now just afiad I might be pulling it to far? The slider thing on my old cable is much shorter.
1968 c10
lowered 3" 4"
Old 12-28-2004, 11:31 PM   #11
76bonanza
76bonanza's Avatar
Also what is the proper way to check tranny fluid have heard several different ways.
1968 c10
lowered 3" 4"
Old 12-29-2004, 12:07 AM   #12
784X4GUY
784X4GUY's Avatar
Well not really but im not there im sure your on the right track. Just mess with it a little more and im sure it will be just right. Oh and the CORRECT way to check automatic tranny fluid it to get the tranny up to operating temp. Then stop and put it in park or in neutral with the PB set. And pull the dipstick wipe it clean then replace it and pull it and check it. Then add as needed hope this helps. Good luck with it...Later Mike
Old 12-29-2004, 12:19 AM   #13
76bonanza
76bonanza's Avatar
Ya my only worry was over pulling the cable.
Thanks for you help also sometimes you just need a little you wont break it it will be ok type of thing ya know.
1968 c10
lowered 3" 4"
Old 12-29-2004, 12:28 AM   #14
76bonanza
76bonanza's Avatar
one more question the detent cable is laying on the bell houseing behind the engine it does not get hot enuf to harm it does it?
1968 c10
lowered 3" 4"
Old 12-29-2004, 12:29 AM   #15
784X4GUY
784X4GUY's Avatar
Yeah man I hear ya, Yeah I would just pull it out and when you feel it get tight that is about enough. And then just try to adjust it to where it will only pull that far or just a smidge further...Later Mike
Old 12-29-2004, 01:24 AM   #16
SanitysBane
on a 700R4, u are suposed to get the throtle linkage at wide open throttle, and then adjust the TV cable so that at WOT the cable is all the way out. atleast thats how i've always done it
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
