12-28-2004, 09:50 PM | #1 |
Vendors, I need poly bushings
I am looking for poly bushings for the rear leaf spring brackets on the front springs of my 72 3/4 4x4.
These are the brackets mounted to the frame with 4 rivits, "L" shaped and hold the upper portion of the shackle. Lower part of the shackle mounts to the front spring, rear eyes. I purchased a lift kit and it comes with all the bushings for the springs but not these. Who has them or where can i get them?
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
12-28-2004, 11:05 PM | #2 |
Currently Blazerless
Kevin, I should have them, I'll check wednesday after work.
12-29-2004, 11:21 AM | #3 |
computer illiterate
if he doesnt and they are the same as 1/2 ton holler at me i think i have some also
72 2wd blazer 72 swb 4x4 |
12-29-2004, 06:29 PM | #4 |
The LMC generic # is 34-1368. It shows they are all the same 67-72 K-5-10-20.
I figured that if the springs had poly, they must make poly for these as well. LMC shows the frame mount and the spring eye mount as the same thing. Both are called spring eye bushings. But then again, does that only pertain to stock springs? I have a 4" lift and aftermarket springs. The frame mounts are still good ol GM. Here is what I want.
12-29-2004, 06:40 PM | #5 |
My mistake. Looks like LMC has poly sets. 34-0107.
Maybe not. Anyone know for sure?
12-29-2004, 06:45 PM | #6 |
Hey Kevin, That is the correct ones. That is none the ones though that the wife put in stock but if you want a set let me know and I will get her to stock them also. Thanks Tim @ Christian's Classics
12-29-2004, 10:04 PM | #7 |
These are the ones you need, if you want to swing by after work thursday I will leave them in the front seat of the burb.
12-29-2004, 10:12 PM | #8 |
Just like to part out trucks!!
You better becareful I know where your burb is!!!!!!!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
12-30-2004, 07:43 AM | #9 |
I will do that. Thanks Rob.
12-30-2004, 09:28 PM | #10 |
Rob, came by after work. No bushings in the Burb.
Randy is the prime suspect. I am waiting on a search warrant. You want in on the raid? Tim, Looks like Rob has what I need. I am making a new list for you. I do not know if it would be worth it for you to stock these. Looks like I am the first to ask for them. I figure that if I am putting poly everywhere else, why not there too.
12-30-2004, 10:44 PM | #11 |
Sorry about that, I forgot to put them in before leaving this morning. I'm off all day friday, you can come back by and if I'm not home for some reason then I will make sure there in the seat.
It looks like Randy was innocent this time!!! |
12-30-2004, 11:44 PM | #12 |
Not guilty, perhaps. Innocent, NEVER!
Headed to KC in the morning. Off tomorrow too. Will swing by on the way back.
