Old 12-28-2004, 09:58 PM   #1
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Question about brake calipers
Will 73 up calipers bolt on the 71-72 spindles? I was told today they would,and just wanted to know for sure.So I thought I would ask you guys.
I need to do brakes,lines,and turn the rotors,just wanna buy the stuff once
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 12-28-2004, 10:08 PM   #2
Solver
Solver's Avatar
If you are changing the rubber brake lines that hook up to caliper maybe, but I do know that 71 1/2 ton uses different caliper than 72 because the hose hook up end is different. Just went through that!
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 12-28-2004, 10:18 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They interchange onto the spindle. The difference is in the rubber hose and where it bolts to the caliper.
Old 12-28-2004, 11:35 PM   #4
Brainchild
Brainchild's Avatar
Thanks for the info guys.I had the same problem today.I busted a line,and of course they only carry the 72 hoses at any of the stores,prolly cause they are the same as the 73 and up hoses.
I had to buy a bandaid at a local junkyard to get back in buisness,but I am going to swap all the stuff out in the next week or so looks like.
Yup 71 calipers are different than 72 as I found out today.The 72 donor had no lines on it,it was just not a good day,too much
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 12-29-2004, 07:45 AM   #5
Tx Firefighter
72 hoses are different than 73 and up hoses. The newer hoses are much longer. They have a bracket where they bolt to the upper control arm and they go further foward where they mount on the frame.
Old 08-07-2009, 02:36 PM   #6
ostncoln
ostncoln's Avatar
Re: Question about brake calipers
sorry to dig this old thread up, but it is exactly what i was wondering.
i just need some clarification, the 73 and up calipers will bolt onto the spindle (?) and the hose is different where it hooks to caliper, but what about where the rubber hose hooks to the hard line? would this be the same throughout?
im working with a 71
thanks
1971 C-10 Project
350/400
5/7 drop
My Slow Build Thread
ostncoln is offline   Reply With Quote
