Old 12-29-2004, 12:24 AM   #1
nevada70chev
Drum Brake...Help
hello all with drum brakes....i need to replace all 4 corners, shoes/drums/wheel cylinders/springs etc. what would i expect to pay for all the parts? is this a major feat for someone who's never done drum brakes? thanks. i was quoted about $650.00 to have it done. it not in the budget.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 12-29-2004, 12:32 AM   #2
nevada70chev
additional ??'s
what is the difference between the finned drum and nonfinned? is one better than the other? if so, how? thanks again.
Old 12-29-2004, 12:34 AM   #3
steve75104
Another 69-20 years later
Brakes, drums, springs, and wheel cylinders just ran me around $150 for parts today. This did not include my wheel bearings, seals, etc. and was front only. Rear brakes are tomorrow.
steve75104 is offline   Reply With Quote
Old 12-29-2004, 11:41 PM   #4
3 on the tree
The finned drums are supposed to dissipate heat quicker. I used to have a 1/2 ton 70 burb, and it had bigger brakes all around than a pickup, maybe you could upgrade without spending much more. Just do one brake at a time, so you have a reference point in case you forget how to put it back together. Invest the money in the proper tools( brake pliers, spring removal tool) I almost lost an eye trying to put a spring back on with regular pliers, they slipped and slammed me hard right in the eye!. Take your time and have fun with the learning curve.
3 on the tree is offline   Reply With Quote
Old 12-30-2004, 02:12 AM   #5
nevada70chev
i don't think mine are currently finned. there is definitely a big difference in cost between the finned and unfinned. just wanted to know the diff and if there is a performance diff. thanks. i'm trying to stay on a budget, but do a quality job.
Old 12-30-2004, 10:40 AM   #6
pierce
pierce's Avatar
There's a hand tool to help get the springs on to make the job easier. My bro-in-law let me use his but it didn't look like it cost alot $$$.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 12-30-2004, 12:22 PM   #7
junkyardjohn
junkyardjohn's Avatar
JON ... IT'S NOT TUFF AT ALL. I'VE TALKED WITH YOU ENOUGH TO KNOW THAT YOU HAVE THE REQUIRED AMOUNT OF COMMON SENCE TO FIGURE IT OUT. JUST TAKE ONE SIDE APART AT A TIME, & USE THE OPPOSITE SIDE AS AN EXAMPLE. THE ONLY SPECIAL TOOLS I USE IS THE TOOL TO REMOVE THE KEEPERS FROM THE NAILS. A SMALL PAIR OF NEEDLE NOSE VISE GRIPS WORK WONDERS FOR REMOVING & INSTALLING THE BIG SPRINGS (I'VE GOT THE BRAKE SPRING REMOVAL TOOL IN MY BOX, BUT I LIKE TO USE VICE GRIPS INSTEAD. IF YOU HAVE TROUBLE WITH IT.. GIVE ME A CALL. OR IF IT'LL WAIT FOR SOME DECENT WEATHER (WE'LL HAVE TO DO IT OUTSIDE) BRING IT DOWN & WE'LL THROW SOME NEW BINDERS ON IT. JOHN
(IT MIGHT BE A GOOD TIME TO UPGRADE TO 73-87 2 1/2" REAR BRAKES.)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
