12-29-2004, 01:23 PM | #1 |
stock radio install
Help i have the stock radio with 2 jambnuts 2 control knobs and 2 selector knobs the radio shafts dont stick out far enough to put the nuts on am i missing a peice?? photo anyone?
12-29-2004, 01:26 PM | #2 |
collector of vintage rust
the stock radio also had two cups to help hold it in place.....that shouldnt keep it from not sticking out the hole.
12-29-2004, 01:28 PM | #3 |
i'm sorry the shaft sticks out the hole but the threads are not out far enough to get a nut started are the cups you have threaded?.
12-29-2004, 02:24 PM | #4 |
More Cowbell....
The cups you are looking for are recessed back into the dash, which will provide plenty threads for the jam nuts to hold onto. I will try to locate a picture for you....or if someone else has a photo of the cups....then it will as clear as day...
ERIC
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
12-29-2004, 02:30 PM | #5 |
http://67-72chevytrucks.com/vboard/s...ght=radio+nuts
Here is a pic that longhornman posted.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-29-2004, 02:40 PM | #6 |
More Cowbell....
Bam. Thanks 71swb4X4.....that is the photo....just install those cups in the holes so they recess toward the engine, and the nuts will go right on.
12-29-2004, 03:30 PM | #7 |
Thanks for the help
thanks you guys are the best!
12-29-2004, 04:51 PM | #8 |
on a shorter note...you can get away with only one cup,if the radio is fastened at the rear to the dash..I know,cause when pulling my radio from a junker,i dropped one through the floor and never did find it.....
