Old 12-29-2004, 05:33 PM   #1
CHEVY & GMC FOREVER
question about tires
Sorry to ask so many questions lately but I am trying to get everything up to specs on my truck, so here is yet another question what should the tires be torqued to on a 1969 chevrolet CST-10 Pickup with Firehawk Indy 500 tires. Also I'm not sure if they are the right tires because the stubs only come out about 1 or 2 inches. Help!!!!!!!!!!!!!!!!!!!!!!!
CHEVY & GMC FOREVER is offline   Reply With Quote
Old 12-29-2004, 11:14 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Gotta say I really have no idea what your question is, sorry. If you want to know the torque for the lug nuts, 90 to 95 lb/ft should do it - doesn't matter what tires are used. If that's not your question, I'm afraid I can't help you - tires don't get torqued, and what stubs are you referring to?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-29-2004, 11:39 PM   #3
CHEVY & GMC FOREVER
lug nuts, sorry I call them stubs, the other part of my question is if those things that stick out of the drum that the tire mounts to are like only 1 or 2 inches would that be safe to drive on?
Old 12-29-2004, 11:47 PM   #4
silvertonguedevil
silvertonguedevil's Avatar
It depends on how far the studs stick out after the wheel is mounted. You should at least be able to say that half of the lugnut has been engaged. So, whatever lugnut, wheel, stud combo that you are using. Half of the threads of the lugnuts should be used. If this doesn't clear anything up, just let me know.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 12-29-2004, 11:47 PM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
the things that look like the threads of a bolt are called lugs/studs, and the nuts that go on them are called lug nuts. as posted above 90ft lbs and do your lugs look broken in any way??? if not they are fine. if they were any longer they would just stick farther out of the lug nut. some one was telling me that you only need the width of the bolt in length for a good hold. EX. your lugs are (IIRC) 7/16 studs so they would only need to thread into the lug nut 7/16 of an inch, so that other 9/16 is just to make you feel better
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 12-29-2004, 11:47 PM   #6
68w/sbc406
68w/sbc406's Avatar
it confused me
Old 12-29-2004, 11:48 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The wheels slip over the lug stuDs and are held on by lug nuts, which thread onto the studs. With the wheels properly mounted and the lug nuts properly tightened, as long as the studs are sticking out beyond the lug nuts at all, you are safe.
- Mike -
RIP El Jay
Old 12-29-2004, 11:52 PM   #8
silvertonguedevil
Originally Posted by 68w/sbc406
it confused me
DAMMIT!!!!
-Greg
1974 C20 Cheyenne
Old 12-30-2004, 12:26 AM   #9
ABHaulR
ABHaulR's Avatar
lugs and nuts
In my state there has to be at least one complete thread showing out of the
lugnut for it to comply with the law
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 12-30-2004, 12:31 AM   #10
Sierra
Okay,
not to confuse anybody, but I think the lug nut should be threaded onto the wheel stud a minimum distance equaling the diameter of the stud. In other words, if you have a 1/2" wheel stud, make sure the lug nut is screwed into the stud at least 1/2". Anything more won't help or hurt.
Sierra is offline   Reply With Quote
Old 12-30-2004, 12:35 AM   #11
CHEVY & GMC FOREVER
well I have the type of LUG NUT that is covered over the end so the lug stud does not stick out of the other end
Old 12-30-2004, 12:39 AM   #12
68w/sbc406
68w/sbc406's Avatar
they are fine
Old 12-30-2004, 12:42 AM   #13
CHEVY & GMC FOREVER
ok thanks for all the help
& FOREVER
Old 12-30-2004, 12:42 AM   #14
Sierra
Then it should be easy to see how far the nut actually travels after first making contact with the wheel stud. You should not have anything to worry about.
