Old 12-30-2004, 12:21 AM   #1
Bubsco
Serpentine belt system
I have a line on a serpentine set up out of a '92 350. I have a '97 350 crate in my burb and trying to figure out if it will fit. I have read allot about that some models need the block drilled and tapped for one of the bolts, but I am not sure what years this applies to?
Anyway, any help on the liklehood the unit would fit, would be great?
Also, does any one know when chevy went to the new AC refrigerent from the factory? and what alternator amperage would a '92 have run with?
Thanks as always for the great board ...
Bubsco is offline   Reply With Quote
Old 12-30-2004, 01:44 PM   #2
70rs/ss
70rs/ss's Avatar
serpentine system
If you use everthing from the 92 model that the serp drive came from it will bolt right up. (use the alt, water pump, pulleys, ac from the 92 vehicle the drive came from and it will bolt up. I used a serp system from a 96 BBC along with the alt, ac, water pump, pulleys and it all bolted up to a 78 454. Boy those rice burners never see my 97 chevy short bed with a 468 hidden in it coming!! Good luck, and I am not sure of the alt specs, but the hole is probably not needed as a 92-95 small block are all but identical in there accessory holes. The only problem might be metric, but I think the 92 bolts should all be metric.
Mike
70rs/ss is offline   Reply With Quote
Old 12-30-2004, 04:47 PM   #3
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Follow THIS thread for more information on serpentine belt conversions
DirtyLarry is offline   Reply With Quote
Old 01-01-2005, 12:26 PM   #4
Bubsco
Thanks, question about the water pump heater hose outlet? I might have missed it in the reading, but I understand that there is no heater hose outlet witht he new style reverse rotation water pumps ..., or are there some model years with and some without? If there is no outlet, what is the configuration of the heater hose hook up???
Old 01-01-2005, 10:42 PM   #5
neonlarry
neonlarry's Avatar
Intake manifold fitting to heater, heater to radiator(you can have a radiator shop brase in a fitting or get a later model radiator.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-02-2005, 10:32 AM   #6
Bubsco
thanks, that is what I thought, have to pull the radiator, just installed the new four core a couple of months ago before I got this serpentine bug ...
Old 01-02-2005, 11:38 AM   #7
neonlarry
neonlarry's Avatar
I got lucky when I did mine the burb had the rad fitting so I just swapped rads. I will eventually have to have the other done to put serp in the burb but for now it works .
