12-30-2004, 04:19 AM | #1 |
No longer a Member
Will a 1981 Front bumper fit a 1976?
will 81 bumper for front fit 76?
12-30-2004, 09:24 AM | #2 |
Slots go on anything!
Not exactly. The frame horns are different, as the 81 bumper has more angle at the bottom. The 81 bumper also has a peak in it, where the rest of your sheetmetal does not.
1974 Jimmy- 5.3/4L80e/NP241 |
12-30-2004, 02:16 PM | #3 |
95 extended cab sportside
thanks i didnt wanna sell an 81 bumper for a 76 thanks alot helped
95 Chevy k 1500 00 Chevy Silverado 1500 07 cobalt Old ladies car] |
12-30-2004, 03:52 PM | #4 |
www.73-87chevytrucks.com
We discussed this the other day, look here:
http://67-72chevytrucks.com/vboard/s....php3?t=132492
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-30-2004, 06:25 PM | #5 |
There's more to consider than the above mentioned info.
The 81 & later bumpers are designed for the 'tapered' 81-up fenders. The 73-80 model fenders don't taper so when you install the later model bumper it will contact the fenders & rub the paint off.
