Old 12-30-2004, 11:44 AM   #1
modmach1
modmach1's Avatar
Dumb? question about flip-kits
Maybe its a dumb question...but here it goes. I wanna lower my truck and i want to c-notch the rear frame. I have looked at a set from Belltech "Lowering Rear Flip Kit" 73/87 GM 1/2 ton -6" drop. from $189 pr.set."
I wonder if the c-notch "steel brick" that shall be mounted on the frame after C- cutting is with the sets?
http://www.moldestuket.com
1971 Mustang Mach-1 429 CJ-R
1973 Mustang Mach-1 289
1975/71 Pontiac Firebird Formula 400
1978 Chevrolet C-10 Fleetside Longbed Scottsdale
1980 Pontiac Phoenix
modmach1 is offline   Reply With Quote
Old 12-30-2004, 02:47 PM   #2
PRUNEDA
'87
PRUNEDA's Avatar
For that price it should it should!!! Check out www.stylinconcepts.com they are a good place that i've ordered from.
PRUNEDA is offline   Reply With Quote
Old 12-30-2004, 03:30 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
From this page: http://www.belltechcorp.com/pages/gmc.htm
Belltech 6" Flip Kit for your GM truck relocates the rear axle on top of the leaf spring pack for the lowest drop available. Kits feature heavy duty, contoured C-sections, heliarc welded saddles, spring plates and shock extensions with a high quality powder coated finish. 5/8" U-bolts, high grade hardware and instructions are included. The system is designed to be used with our Dropped Front Spindles and springs for the ultimate drop.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-30-2004, 06:06 PM   #4
modmach1
modmach1's Avatar
Thanks Guys
Ain`t no ride like a low ride
