12-30-2004, 05:08 PM | #1 |
#1 OU Soonerfan
No Freakin' Heater Help!!!!!!!
Hey guys my heater/ air conditioner quit working. Everytime I move the switch up and down it does nothing. Does anyone think the switch is bad?How often do those go bad? Or would it be something else? I checked the fuse and it was ok. Any comments would be grand. Thanks
12-30-2004, 05:18 PM | #2 |
I assume when you say you move the switch you are talking about the fan switch. I had the same problem in the hot Texas summer. I changed the switch and the fuse, but I think my problem had to do with the ground wire that is attached under the hood. Below is a link to the thread where I asked the same question. The responses there should help you.
http://207.44.196.117/vboard/showthread.php3?t=117741
Hook'em Last edited by Hook'em; 12-30-2004 at 05:20 PM. |
12-30-2004, 05:24 PM | #3 |
I had the same problem last year. Like hook'em said, check your ground wire to your blower motor out under the hood, passenger side. Mine was corroded up to the point I had lost my ground. The motor uses a case ground, so if your brave enough...turn on the switch and ground it out, see if it'll start running. Or just check where the wire attaches to the firewall and clean up both sides. Good luck! This isn't a good time of year for no heat.
Doug Simmons 1972 LWB Cheyenne- blue w/ white top 1998 Z28 Camaro (quicksilver) |
12-30-2004, 05:45 PM | #4 |
also check and make sure your ground wire is still grounding the blower motor. Mine quit on me as well but al it was, was the ground
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
12-30-2004, 06:23 PM | #5 |
Watch out for your cornhole !
Get a 5 dollar test light and check the circuit from the power source to the blower motor. That way, you can see if it's the fuse, wiring, switch, motor, blower resistor, or what.
12-30-2004, 06:34 PM | #6 |
#1 OU Soonerfan
Thanks for the info guys, Im on way to go jack with it right now.
12-31-2004, 11:28 AM | #7 |
#1 OU Soonerfan
hey guys, I got to check the ground and it was just fine. Does anyone think the motor itself is bad?
12-31-2004, 12:16 PM | #8 | |
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
