![]() Join Date: Jun 2002
Swaybar????????????
I Want A Swaybar For The Rear Of My 72. What Do I Need To Look For In The Junk Yards. Also What Will Fit On The Front Larger Than The Standard Size. Thanks , Buddy
Mike
Read this link...http://www.low69cst.freeservers.com/CamaroBar.htm
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
That link doesn't work anymore. I used a 89 camaro bar. Flipped it around on the axle and it fit fine. Heres a pic, if you want some more just let me know.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Got Light Emitting Diode?
worked fine for me. would something like that still work on an airbagged truck???
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
