Old 12-31-2004, 05:09 PM   #1
special70gmc
special70gmc's Avatar
got the tunnel ram all together!!!!
i got my tunnel ram and the holleys all bolted up and ready to go in on monday, i just got the hilborn scoop and painted it to mach the new covers too, i cant wait to see it on the truck, its gonna be sick!!!
-kyle
here it is check it out...........
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-31-2004, 05:12 PM   #2
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
what you doing with your old air gap? wanna sell it?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 12-31-2004, 05:25 PM   #3
special70gmc
maybe im gonna see how i get this setup to run on there first but i might -kyle
1958 belair 2door
Old 12-31-2004, 05:49 PM   #4
meathead95
computer illiterate
meathead95's Avatar
i have never seen anyone run the carb spacers on a tunnel ram before. what is the theory behind it?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 12-31-2004, 05:49 PM   #5
special70gmc
i just relixed theres no vacume port for my brake booster/tranny line what do i do? actually theres no vacime ports whatsoever only on the carbs in the metering block on the primary sides. does anybody have a solution?
thanks -kyle
the carb spacers.... i read a dyno test in some magizine (super chevy) wherethey were testing tunnel rams with and w/o spacers and this made the most power and torque for some reason this was awile ago but i belive it was a 2'' like i got
1958 belair 2door
Old 12-31-2004, 06:02 PM   #6
Big J
Its lookin' like a Blazer!
Big J's Avatar
Sweeeeeeettttttt!!!!!!!!!!!
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 12-31-2004, 06:13 PM   #7
GMC71k20
thats gonna look killer, how high do you plan on winding that motor up?
GMC71k20 is offline   Reply With Quote
Old 12-31-2004, 06:29 PM   #8
67cst
i love summertime
67cst's Avatar
you should use those black m/t valve covers and send me those aluminum ones
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 12-31-2004, 06:31 PM   #9
67cst
i love summertime
67cst's Avatar
oh wait i didnt read your post that well, are you going to be selling the aluminum finned covers? if so id like them!
thanks, DEREK
Old 12-31-2004, 06:43 PM   #10
special70gmc
no i might sell the intake the rpm airgap the valve covers im keeping cause its what came stock on my LT-1 im actually gonna see which i like better. aas far as rpms its seen 7000rpm a few time in its life but thats what its built for takin a beating im really excited to get this thing on and get it painted up
thanks -kyle
1958 belair 2door
Old 12-31-2004, 07:06 PM   #11
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Looks good man can't wait to see it all together...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 12-31-2004, 09:22 PM   #12
RON WOODGEARD
Resident Young Old Dude !
Kyle,,, It's gona be Killer Dude...
And yes, The Spacers will give better bottom end and with that Small Chamber on the Tunnel Ram they will help the Vacuum situation.. The Hilborn Scoop just Tops it off..
I had to Drill a hole for Vacuum accessories just under the carb base on the rear of the Manifold on one of my Tunnel Rams. Tap it for the Vacuum adaptor.
RON WOODGEARD is offline   Reply With Quote
Old 12-31-2004, 10:31 PM   #13
arkracing
Weekend Warrior
Carb spacers might cause a huge dead spot in the throttle response - when you jump on it. but try it first and see what happens. what size are the carbs? CFM?? - lets us know how it performs??? im interested to see if you like it compared to the AirGap - is the truck primarily street driven?
as far as the no vacuum ports on the intake...you can drill a hole in one of the rear intake tunnels, or in the bottom of the upper Plenumn - like on the bottom side of the intake top where the tws carbs are mounted then tap it with a pipe tap and put a fitting in it.
or find a big vacuum port on one of the carbs..near the base as low as possible
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-01-2005, 06:35 AM   #14
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
8,000rpm here we come....Unfortunately your lowend is gonna suffer greatly but if you have built and motor that can take the High RPMs (heads that FLOW!) then you will make killer power.
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 01-01-2005, 06:38 AM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WOW
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
