Got Light Emitting Diode?
control arm bushings
can you change these style bushings to the newer style urathane ones??? what does it take??? are these ones better since they are greasable???
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Ttt
Watch out for your cornhole !
![]() Join Date: Jun 2003
There's no way to retrofit the urethane bushings into that type of control arm.
But, the steel type of bushing that you have there actually are firmer than the urethane type are, plus, since you can service them with grease, they will last longer.
k so i wont mess with it. thats the info i was looking for. thanks TX
