Old 01-01-2005, 09:14 AM   #1
JimKshortstep4x4
Smile Cab change, frame mounts
As part of the cab change we are redoing the frame as necessary prior to painting. The previous owner had repaired the frame frame mounts and his bird dropping welding on the repairs looked shaky. I made up some plates, (3 1/2 x 3 1/2 for the front mounts, 3 1/2 x 3 for the rear) with 1 1/2 holes bored into them. The plates are 1/8 thick. With my son's greatly needed assistance we repaired the four frame mounts.
We started by cutting out the old weld using a sawzall and air cutoff grinder.
pic 1 shows what we cut out, some of the others were worse.
pic 2 shows the cut out with the old metal removed and the area prepared for welding.
pic 3 shows positioning of the plate ready for welding, (we located the plate using the center of the hole for reference).
pic 4 shows the plate Craig welded and ground, ready for prime and paint.
Jim
Old 01-01-2005, 09:18 AM   #2
vtblazer
vtblazer's Avatar
Great Work
Doing it right the first time is always the way to go!
Nice job on the repairs.
vtblazer is offline   Reply With Quote
Old 01-01-2005, 09:23 AM   #3
JimKshortstep4x4
Smile
vt blazer,
You are right and it did not take long to do the repair right. The plates appear to be the way to go.
Jim
Old 01-01-2005, 11:50 AM   #4
72MARIO
72MARIO's Avatar
Looks good.
I also had to repair my frame the same way you could never tell though.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-01-2005, 05:33 PM   #5
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Nice Work!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 01-01-2005, 05:45 PM   #6
Rollie396
someday it will be done!
Rollie396's Avatar
looks good!I did the same thing to mine just last week.I couldn't believe how pitted the surface of the brackets were!Took less than an hour and it's good for another 30+ yrs .
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 01-01-2005, 11:04 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Looks good Jim. Did you contemplate trying to find good mounts and cut off the rivets and bolt on some from the southwest?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-02-2005, 07:59 AM   #8
JimKshortstep4x4
Smile
JIMs70GMC,
Since the brackets were in good shape and the rivets held the brackets tightly to the frame, changing them did not seem like a good option.
I am not sure if you can find brackets that did not have some hole damage, anyway.
Jim
Old 01-02-2005, 10:58 AM   #9
zooza
nice job, its good that you show pretty much all aspects of the repair. thanks.!
zooza is offline   Reply With Quote
