01-01-2005, 10:23 AM | #1 |
Welding Gas
I am buying a Lincoln 135 welder and was wondering what size bottle of gas I should get and how long will it last. Also how much should I expect to pay for it.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
01-01-2005, 10:43 AM | #2 |
Watch out for your cornhole !
For home usage on your machine, a 40 cu/ft bottle of 75/25 is ideal. I use a 40 myself and also have a small Lincoln welder like yours. You'll get plenty of arc time out of the bottle before it needs refill. I weld a lot and working all day in the shop, I can empty one. That's all day doing fab work like building gates or fence panels. For truck welding like patch panels and filling holes, you may go through 2 or 3 bottles a year. Also, you won't believe the improvement in your welding once you go to gas versus flux core. It's worth every penny.
Cheapest place for you wll be Ft Worth Welding Supply on Sylvania or Riverside. I never can remember. Anyway, that's the cheapest place in town. Expect to pay right at 100 bucks to buy the bottle and it comes full. Each refill is 12 bucks. Even though you "own" your bottle after the first 100 cost, don't expect a shiny new bottle. You'll get an ugly beat up bottle for sure. It doesn't matter though, each time you take an empty in and give them the 12 bucks, you'll just be swapping your bottle for another bottle. You own "a" bottle not "one particular" bottle.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-01-2005 at 10:46 AM. |
01-01-2005, 11:22 AM | #3 | |
01-01-2005, 12:29 PM | #4 |
I am doing the same thing as 72 Blazerdude, When you buy a bottle you still have to buy the regulator, correct? How much does that add?
01-01-2005, 01:53 PM | #5 |
regulator
it should come with your welder I know it came with my Hobart
01-01-2005, 02:04 PM | #6 | |
01-01-2005, 05:09 PM | #7 |
I've seen them range from $35.00 to $80.00 on E Bay. Is that just a diff. in quality? I also noticed some have a little tube to tell how much gas is left in the bottle. Does anyone have a recomendation? Who to stay away from? Thanks, Mike
01-01-2005, 06:05 PM | #8 |
Careful, they attack...
Victor, Airgas, and Linde are good ones. Get a used one, they last forever and are pretty pricey to buy new. The little tube is for showing the amount of flow, not the amount left in the bottle. You see that from the pressure guage, the needle will not move for a very long time, but when it does, it goes fast. You can expect to get about 3 hrs of "trigger" time from a 40 cf bottle. That is a very long time when you consider how short your trigger pulls are when welding on sheet metal. Mine lasted about 2.5 months before starting to go down. I haven't got it filled, but the last time I called AGA, they said about $25 to exchange it. I payed $85 for mine, and that was in August.
01-01-2005, 08:04 PM | #9 |
To convert from flux core to gas you need more than the regulator.
You need the gas solenoid, hose, nozzle for the gun, etc.. Lincoln sells a kit you can buy at Home Depot for about 100 bucks. It has everything you need but the bottle.
01-01-2005, 10:39 PM | #10 |
Found this article on different gases.....might be a good read.
http://bc4x4.com/tech/2002/gases/
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
01-01-2005, 11:14 PM | #11 |
Weekend Warrior
$12 for a refill...that is stealing it. Wow i wish i could get it that cheap.
it is like $37 for a 40CubicFootRefill at the local welding shop near the garage. anybody know if there is a "size limit to own" can you only buy outright upto a certain CubicFoot Cylinder and then after that you have to rent it? only cause I would like a little larger bottle, I guess I could just buy a second bottle though
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-01-2005, 11:24 PM | #12 |
user # 2756
I just "upgraded" my lincoln 100 HD for gas. I can't wait to start welding. The kit for the lincoln had everything but the bottle as said above it was real easy to convert. Everybody I talked to has said the same thing as above 75/25 mix CO2 and argon. The kit came with 2lbs of .025 wire.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-01-2005, 11:58 PM | #13 | |
My little Lincoln 100 Mig welder has served me real well. I've built tons of gates, fences, car floorboards, patch panels, etc, with mine. I can't imagine how many rolls of wire I've run through it. I have converted mine to use the big rolls instead of the little ones too.
01-02-2005, 03:13 AM | #14 | |
It should also be noted my machine pulls wire on it's side (stupidest idea I've ever hear of) |
01-02-2005, 09:30 AM | #15 |
Never enough time!!
Doc, My Century 250 pulls the spool on its side too....no problems so far(had it 2-3 years) I use 10# or 2# spools, just change the tension on the spool and/or wire feed, works just fine. Wire is cheaper in the bigger spools, by the # that is. Good Luck, Gord
01-02-2005, 10:28 AM | #16 |
Gas is really the only way to go with sheetmetal. You only should use flux when you are welding outside. Gas doesn't do well outside since even a small breeze will blow it away and you then have no shielding. You get much cleaner welds that take little to no time to clean up. The CO2/Argon mix is a great general purpose mix. You only need pure Argon if you are welding aluminum. The bigger spools shouldn't be a problem for your small machine. Just don't tighten it down too much and it won't know the difference.
01-02-2005, 11:28 AM | #17 | |
01-02-2005, 11:52 AM | #18 |
Some come ready to switch to gas. It depends on your welder. Read what the instructions say about changing to gas. It's not universal that you have to buy a separate kit. Some of the lower priced units require a kit to go to gas since they were sold as a Wire Feed welder, not a MIG. MIG is gas only. If yours says it can do both with just adding a bottle and switching polarity, then you should be good to go. Did yours come with a regulator? If not, you will have to buy one.
01-02-2005, 12:15 PM | #19 |
No it did not. I am weighing the options of adding gas, If it is just a matter of having to clean up the welds, we can do a bunch of grinding for close to $200.00
P.S. it was sold as a dual wire feed mig welder. |
01-02-2005, 12:27 PM | #20 |
Using gas is more than just having cleaner welds, you get BETTER welds, better penetration, and better control. If your welder didn't come with the stuff to make it connect to gas, then it's an optional kit from the welder mfr. It should be listed in the instructions as a kit and part number. You need to order that before you can use gas. It was sold as a dual feed welder, because you CAN add gass to it for MIG, but it's not included. My Lincoln 175 came ready for gas, but I bought it that way. It was the smallest and best 240VAC welder I could get. If you don't want to spend the money for the gas conversion, then don't. Obviously, you didn't think you were going to use it or you would have got a MIG in the first place. You can do fine with flux, but it will add more time to your project. It's not the end of the world.
01-02-2005, 03:11 PM | #21 |
I have a 55cu ft bottle. Haven't come close to emptying it yet. You just gotta weigh how far it is to get it filled/how much hassle, and how much you will need at one time. For a weekend warrior like me, who just does random smaller projects, a smaller bottle is fine. Also gotta think about one more thing, do you carry your welder with you to the project or do you bring the project to your welder? Carrying a huge bottle around with you may not be the most efficient.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
01-03-2005, 12:49 AM | #22 | |
01-03-2005, 10:33 AM | #23 |
Never enough time!!
Just make sure it is insured before you set it on fire ...that way you at least get some of your money back out of it!! Everyone be careful out there though...the welder I got came from my widow neighbor, about 3 years ago her boyfriend/husband got this welder from her as a gift...decided he wanted to make a yard roller out of a 55 gallon drum, not sure what had been in that drum but, first arc he struck on that drum...it exploded, the top blew off hitting him in the head, sadly he died before they got him to the hospital. So just know what your dealing with and safety first P.S. Looked like burnt oil that's all that was left in the barrel....would old oil cause an explosion? This still puzzles me...no build up of pressure from the heat, it was just a small arc is all we could find on that whole barrel and there was another person there and he said they just started when it exploded.
01-03-2005, 11:04 AM | #24 |
One of our board members (great guy) is trying to set up as a dealer for Campbell Hausfeld. Rob Pierce from Cinci---. Know on the board as "Pierce". Rob got me a great deal on a Mig/Flux 120 that is complete with Flux and gas capability. Everything but the bottle. Package deal had gloves, face shield hat, wire brushes, hammer, 3 tips, 3 size feeders for different wires, wheels, etc. Nice package. Infiniate wire speed, 4 heat ranges--. Gas regulator but no gauges---. 5-3-1 warranty.
I've been pricing the top 3 for a while on e-bay---Miller, Lincoln & Hobart but this was about $200. less and as a hobbiest, this should do me fine. Shoot "Pierce" a PM or e-mail "pierce@fuse.net" if interested--tell him Huck sent you! hehehehe Huck |
01-03-2005, 07:20 PM | #25 | |
If it's petroleum based, it'll prolly burn. |
