01-01-2005, 11:20 PM | #1 |
It followed me home?
tail light troubles
My drivers side taillight used to go out once in a while and then it would just start working again at random. Now it's gone out completly and was hoping to know if there is a common place for wires to short, or the best route to narrowing down the problem. Thanks
Oh and yes I did try a new bulb
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-01-2005, 11:44 PM | #2 |
I would check the wiring at the back of the socket first, usually where the soldering or splicing is done is where a connection goes bad first.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
01-02-2005, 12:41 AM | #3 |
Well I found the problem, WTF are people thinking when they do crap like this? Anyway, anyone have a harness plug (whatever it's called) to sell?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-02-2005 at 12:45 AM. |
01-02-2005, 01:22 AM | #4 |
Adam,
That's how the back of my truck's wiring used to look. It's not hard to figure out once you figure out which wires are your +'s, one side of that plug goes TO the tailights, the other side comes from the cab, via the driver side framerail. |
01-02-2005, 01:40 AM | #5 | |
01-02-2005, 02:04 AM | #6 |
all the plug is for, is for trailer wiring
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
01-02-2005, 08:52 PM | #7 |
North Coast, baby!
Man do I know what you're feeling Adam. Its not wiring but sheetmetal. The PO (my older but not so wiser brother) decided the best place to run the coax cable for the CB antenna was to drill a hole right through the top of the cab through both sections! Just let me say that it looks great (NOT). Thats going to be a fun fix when the time comes.
Brad 79 Scottsdale C20 350/350 3.73's Still running full CA smog gear! |
