Old 01-02-2005, 04:22 AM   #1
HeavyD
HeavyD's Avatar
Wiper problems
Hi. My wipers just started acting up today. They turn on but then "freeze" halfway through the cycle and will not move again unless I get out and force them down. Is the wiper motor shot? Do they get weak over time? Thanks.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 01-02-2005, 07:46 AM   #2
JimKshortstep4x4
Smile
I would check the switch, making sure that it is grounded well. If the switch is good, then I would suspect the wiper motor.
Since the switch actually "grounds" the wiper motor, you can take a jumper wire and ground one of the terminals on the wiper motor to check it out.
Jim
