01-02-2005, 12:51 PM | #1 |
fuel sending unit uninstall question
How do I get the old unit out? There are a few tabs that look like they need to be pushed in or out to unluck the sender, but they're old and I don't want to break anything. Any hints? I've run the search and haven't found any answers.
01-02-2005, 01:48 PM | #2 |
anyone?
01-02-2005, 02:06 PM | #3 | |
Are you working on a behind the seat tank? Probably it has a ring that you need to rotate counterclockwise? Those tabs you see,- Use a punch/old screwdriver and tap Not To Hard -the ring will rotate and move tabs into open slots where it will spring free. The sender will lift right out. You do need a new O Ring gasket to put back together. Hope i explained that well enough. Other tanks/not just behind the seat units fit together the same way. -Steve
01-02-2005, 02:09 PM | #4 |
67-72 Addict!
Unscrew the threaded nut first on the fuel line. Use a block of wood to tap the lock ring loose. You have to tilt it out slowly.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-02-2005, 03:14 PM | #5 |
Well, there are 2 tabs that fit into slots on the outside of the main ring. Do I need to do anything with these?
01-02-2005, 05:15 PM | #6 |
Well, I gave it a try and got that bugger out. Thanks for the help. Pushing the tangs looked too easy, and I didn't want to screw this thing up. Thanks.
