Old 01-02-2005, 02:50 PM   #1
tmad
Question ALT. BRACKET HELP (pic maybe)
Well now that Ive installed the power steering its on to the job of replacing a bad intake gasket! I used the rubber end pieces against my better judgement and sure enough it blew out!!! Anyway I need some help, my 67 has the oringinal 283 installed, my alt is mounted high on the right side facing the engine just above the power steering pump, before I installed the headers the old alt bracket mounted to the end of the exhaust manifold when I reassembled things I made or maybe cobbled a bracket to hold the alt. Does anybody know where I can get a bracket for this application or maybe have a pic of what will work here. I have searched and searched but cant find a good pic to use. I would be greatfull for any help!!!!!!!!!!! Thanks again for all the power steering help last week!!!!!!!!!! Todd
tmad is offline   Reply With Quote
Old 01-02-2005, 04:59 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Do your heads have tapped bolt holes in the end of them?
If so, just use a 69-72 alternator bracket.
Old 01-02-2005, 07:58 PM   #3
JimKshortstep4x4
Smile
I don't believe the 67 283 engines had tapped holes in the head. Summit has an aftermarket bracket for headers or someone on the parts board may have a good used one.
Jim
Old 01-02-2005, 08:12 PM   #4
tmad
No I dont have any tapped holes in the head. I will check Summit.
Old 01-03-2005, 01:37 PM   #5
tmad
Does anybody have a pic of one of these aftermarket brackets installed?
Old 01-04-2005, 12:42 PM   #6
Zonaman
Zonaman's Avatar
Here's a set up from Old Air . They do AC units but maybe you can use something from them. I had to move my alternator over to the right when I put the air in. Brackets worked fine except I had to cut a small piece from the bottom to allow for the headers.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 01-04-2005, 03:12 PM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7945507508
sneakysnake is offline   Reply With Quote
