HOW do you get the angle iron off the bed inside? The one at the bottom by the wood. I can't find where it is welded. Thanks johnj 58 long bed
you laugh at me cause i'm different ; i laugh at you cause you're the same ![]() |
Clean the angle up a little with 80 grit sandpaper and you will see spotwelds about every 8 inches then use a drillbit or spot weld cutter.
Rest in Peace Ed. Thanks for all the good times. |
Thanks Mother. Do you carry them for a 97" bed? johnj
We have them in steel ,stainless steel and polished stainless steel punched or unpunched.
