Old 01-02-2005, 06:00 PM   #1
Tanker350
F/S 72 GMC C-15 Project needs finished in So. Cal
I have to sell my 1972 GMC C-1500. I have collected, re-built, replaced, or bought so many parts, that it would be a DAMN GOOD truck when finished.
The engine is a 4 bolt main 350 from a 1969 Camaro.The trucks doesn't run b/c I'm looking for a Manual 3 speed bearing retainer. If I can find that part it will start and run with no problems.Here are the items I replaced on the
MOTOR
-Edelbrock 750cfm #1497 Carb
-Edelbrock Performer RPM intake manifold #7101
-Edelbrock Performer link #7800 timing chain
-HEI Distributor w/ 40,000v coil
-Milodon oil pan with 1 piece gasket
-Alternator
-Starter
-Fuel pump
-Double bearing water pump
-Battery
-Clutch Fan
-Flex Fan
-Power steering(rebuilt the gear box, pitman arm, lines, pump with correct brackets)
-Wires, Valve covers
-Engine Harness
-Remote Starter Solinoid
-Flywheel ring gear
-clutch disc
-pressure plate, throwout bearing, pilot bearing
Rear Differential
-new axles, 3.73 gears, 4 series Eaton posi unit, bearings and install kit, pinion yoke
-New 2 piece driveshaft with center carrier bearing, and u-joints
-new monroe shocks
Rear Drum Brakes
-new drums, shoes, wheel cylinders, new spring install kit
Gas Tank
- I have the 1 inside the cab, but I also installed a 25 gallon tank under the bed. I need to make a filler door to be able to use this. New straps, sending unit, electric fuel pump.
Front Disc brakes
-new calipers, pads, pistons and seals, master cylinder
Front Suspension/Steering
-upper and lower MOOG ball joints
-inner MOOG tie rods
-Front sway bar, MOOG bushings, frame to bar brackets
-new monroe shocks
Wheels and tires
-Modern Chevy Rims with beauty rings, and chrome GMC center caps, lug nuts
-4 Brand new (100 miles) Goodyear Conquest AT 265/75/15
Interior
-new keyed door locks, ingnition, glove box, gas cap
-new ignition switch, ign. wiring, dimmer switch, door jam switches
-New glovebox, dome light, washer pump rebuild
-New heater core, re built engine heater box, inside housing,
-Chrome trim on the doors inside
-New dual exhaust exiting in front of back wheels
-New polyurethane cab/rad/ body mounts with new bolts
-All the bed bolts that attach the side panels, wheel arches are SS
-I havent installed but I have brand new outer rocker panels
-new inner rocker panels
-Floor boards
-kick panels
I will also give who ever buys my truck:
-700r4 tranny, needs rebuilt
-rebuilt tilt, auto, cruise, steering column
-Linkage from tranny to column
-Brand new Power brake booster with new master cyl, proport. valve(comes with the mounting brackets and rod
-NEW MOOG upper and lower control arm shaft kits
-new MOOG inner and outer tie rods
-Brand new ULTRA LITE AUTOMETER GUAGES still in boxes
-#4437 2 5/8 elect. water temp
-#4427 2 5/8 elect. oil pressure
-#4491 2 5/8 elect. voltmeter
-4375 2 1/16 air/fuel ratio Elect
-2244 o2 sensor kit with wiring, sensor, and items to tap and weld to hedders
-Tool box door with a solid not cracked tool box, latch, hinges
-73-87 Front crossmember that has crossmember, upper & lower control arms,
-Original set of Rims that came with the GMC, plus Three sets of hub caps
-PLUS I'LL GIVE YOU EVERY SINGLE PIECE OF CHEVY PARTS THAT I HAVE, WHICH TOTALS LEFT OVERS FOR A 68 C-20 3/4, THIS TRUCK, AND A COUPLE MORE.
I need to sell this. So I may work with you on the price.
I'm asking $5,000 obo, and I live in So Cal.
Tanker350 is offline   Reply With Quote
Old 01-02-2005, 06:06 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Lets see some pics, also are you willing to sell any of the "throw in" parts?
If so im interested in the M/C& booster.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 01-02-2005, 07:10 PM   #3
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
Dang that was a lot of work you did to that truck, I'm tired just reading about it.
Does the tilt have the factory cruise setup, if so I would be interested in it if I can afford it.
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 01-02-2005, 08:13 PM   #4
Tanker350
Borax, I have a thread already selling the booster/MC. I'm asking $155.00 plus shipping.
Hot rod, its not factory, its a van tilt, auto, with the wiring to the shift handle type, that would be wired to the 700r4 I'm giving away to who ever buys my truck.
Old 01-03-2005, 03:31 AM   #5
Tanker350
ttt
Old 01-03-2005, 11:41 AM   #6
boraxman
Keepin an eye out
boraxman's Avatar
[QUOTE=Tanker350]Borax, I have a thread already selling the booster/MC. I'm asking $155.00 plus shipping.[QUOTE]
I see its for 3/4 ton, need 1/2.....TTT for ya.
ZIP 91351
Old 01-07-2005, 01:46 AM   #7
Tanker350
ttt
