Got Big Block?
I killed my lights!
Dummy me was installing some autometer gauges in my '68. I didn't have my test light and was looking for something that was hot when I turned the lights on, I touched the wire for the bulb in one of my autometer gauges to a fuse in the fuse block and got a pretty good spark.
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 01-02-2005 at 07:30 PM. |
#2 | |
Inline 69
same fuse
its all about the +6 inches
Agreed...may times they will blow up in the metal end where you can't see it.
Definitely sounds like the fuse...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Take a $10. bill & go buy yourself a pack of fuses and a test light!
Got Big Block?
I found my test light and I have fuses. All the fuses look good and test hot.... I tested the plug going into the instrument cluster and only the pin on the far left was hot. What part of the fuse block do the wires that feed the tail lights and dome lights come out of?
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 01-02-2005 at 09:45 PM. |
![]() Join Date: Feb 2002
Test the inst bulbs, too. You may have flash-fried them.
Got Big Block?
??????? I started pulling fuses and putting them back in. All looked good. Tried the lights and they worked....? Anyway, thanks for the help.
"Experience is what you get when you didn't get what you wanted." |
