Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-02-2005, 07:56 PM   #1
Porkchop
Porkchop's Avatar
engine and truck for sale
Small Block Chevy 355
-2 bolt main block bored .030" over
-new freeze plugs and cam bearings
-turned cast iron crank
-new rods
-new dished pistons
-new bearings, rings, and gaskets
*the entire rotating assembly was balanced
-new vortec heads
-Crane 1.5 ratio self aligning roller tip rockers
-.420" .443" lift Comp Cam with hydrolic lifters and
pushrods
-ceramic coated flotech headers (made for a 67-72
chevy truck but they may fit other applications)
-Edelbrock performer rpm airgap aluminum intake
manifold
-Edelbrock 750 cfm manual choke carb
-Pro-billet MSD distributer and MSD wires
-New spark plugs
-new timing gears and chain
-new high volume water pump
-new oil pan and oil pump
-chrome accessories (water neck, valve covers,
aircleaner, dipstick etc.)
-some pulleys and brackets (they have all been painted with high temp paint.
-flexplate (for auto tranny) flywheel and clutch
-2 starters
This engine has never been run but has remained
covered and oiled, and it's been rotated periodically.
This engine has a compression ratio somewhere in the
vicinity of 9.5 to 1. I chose the somewhat small camshaft lift,although larger than stock, because I was going to put it in my truck. You could easily swap in another cam if you wanted to run at higher rpms.
I really need all of the money I can get out of this, so I am asking $2800(this is less than what it is worth in parts), or I would be willing to accept trades for something (doesn’t have to be car related)
also, I have the truck that the engine was supposed to go in for sale. It's a 69 3/4 ton with the granny four speed. It has no engine. Nothing is bolted to the frame, but the bed and cab are sitting on it (the front clip is in the bed). the bed is in great shape (came from south) with only a few rust spot in the tailgate and one where the single exhaust exited. The frame/suspension is fine with only some surface rust. The cab is in rough shape and would require alot of welding. The doors could be fixed with lower skins. The fenders need their corners replaced. Inner fenders, and radiator support are rough also. I will throw in a radiator that I only used in the truck for less than 500 miles, two cab corners, and two rocker panels.
for just the truck-$600
truck minus bed- free
truck plus my engine- $3000
just the bed- make an offer
Again, I may be willing to accept trades
thanks
brad
Porkchop is offline   Reply With Quote
Old 01-02-2005, 08:26 PM   #2
truckman32
AND HOLDING ON TO THE C10
truckman32's Avatar
would you trade the engine to a 95 f**D ranger
66 swb/ss chevy c10 SOLD
62 swb/fs chevy c10 :p SOLD
84 swb/fs chevy c10
91 sdime 383/th350
truckman32 is offline   Reply With Quote
Old 01-02-2005, 09:29 PM   #3
Porkchop
Porkchop's Avatar
It may be a possibility. Could you give me some more information on it?
Old 01-05-2005, 06:18 PM   #4
Porkchop
Porkchop's Avatar
Ttt
