01-02-2005, 08:03 PM | #1 |
AND HOLDING ON TO THE C10
help!!!!!how do i remove my key switch
well i think my key switch is going out of my 84 chevy c10,it is getting real stiff when i start it and when i shut it off,anybody know what this could be, HOW DO I REMOVE THE SWITCH this is somehting i have never had to deal with, if it's not the switch ,could it be the rod that runs to the ?hum i can't remember what it's called it's right on the bottom part of the steering column,the rod hooks to it dang it i'm losing my memory lol
66 swb/ss chevy c10 SOLD 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 91 sdime 383/th350 Last edited by truckman32; 01-02-2005 at 08:05 PM. |
01-02-2005, 08:37 PM | #2 |
you need to pull the steering wheel off i havent done it in years but i think its pretty simple once you get the wheel off
01-02-2005, 08:57 PM | #3 |
What I drive
Just done this today!
Take the steering wheel off........have to have a steering wheel puller. Then you have to pull the locking plate off.................also have to have a tool made especially for that, the remove the 3 screws holding the turn signal cam down, then pull the little white plastic thing that is above the torx screw that holds the lock cylinder in place, then pull it straight out.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
01-02-2005, 09:10 PM | #4 |
Just had the same problem in my 77 Blazer.....the lock was coming apart. When I got it out several of the spring were coming out of the backside of the lock.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-02-2005, 11:25 PM | #5 | |
66 swb/ss chevy c10 SOLD 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 91 sdime 383/th350 |
01-02-2005, 11:36 PM | #6 |
That tool is used to depress the steering lock plate just far enough to remove the keeper ring.
Bought one several years back from my locksmith supply house. Mine came with two differnt main shafts for different vehicles (threads are different) It's worth every cent even if you don't use it very often.
01-02-2005, 11:40 PM | #7 |
Gentleman Jim Driver
It's called a lock plate remover. They sell them pretty cheap at all the chain auto parts stores or even harbor freight.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
01-03-2005, 10:51 AM | #8 |
I would replace the switch on top of the column first. I was having a real hard time getting mine to turn over far enough to engage the switch and it turned out to be the 12.00 switch. It is located on top of the column under the dash. I bought a new one at NAPA and they had it in stock. All you have to do is un plug it and loosen a couple of screws.
01-03-2005, 11:03 AM | #9 |
Insert Witty Text Here
I just did this as well. I also replaced the wiper/cruise/blinker lever and the blinker switch inside the column. What a pain!
I used this guide. It is for a fiero, but it looks the same as mine. Follow it up to the pic that is labeled "lock cylinder screw" and "key buzer switch." When you get to that point, remove the lock cylinder screw with a T20 torx screwdriver. The cylinder should slide right out. The pics on the site show the tool you need. http://home.t-online.de/home/O_Scholz/steering.html Slonaker |
01-03-2005, 02:21 PM | #10 | |
01-03-2005, 02:26 PM | #11 | |
66 swb/ss chevy c10 SOLD 62 swb/fs chevy c10 :p SOLD 84 swb/fs chevy c10 91 sdime 383/th350 Last edited by truckman32; 01-03-2005 at 02:29 PM. |
01-03-2005, 04:42 PM | #12 |
No, that didn't happen to mine but the rod that goes to the switch was bending when I tried to engage the switch and it finally got to where I had to use a pair of pliesrs to grab the rod and push on it to get it to start. To me that sounds like that is your problem. I think my switch fell apart when I took it off.
01-03-2005, 06:05 PM | #13 | |
