Old 01-02-2005, 09:26 PM   #1
67pro-street
67pro-street's Avatar
oil capacity in a 700r4??
i am installing a 700r4 and i was wondering how much oil i should put in if the transmission and converter were both dry. thanks,
67pro-street
67pro-street is offline   Reply With Quote
Old 01-02-2005, 10:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
dump one or two in the converter before bolting it all up, then pour 4 quarts in and start it up.
Put tranny in gear for a moment, then put back in park and check the level. Bring it to the bottom of the add line, maybe a tick lower, then drive it and bring it to operating temp...a couple miles should do...no hot rodding either. just normal driving.
Then check it again and bring it to the full line. I personally like keeping them a tick below full so that when you get the tranny real hot, it will only get to the full line instead of overfull, which will cause foam to form and that will take miles off the clutch packs and bearings and stuff.
Old 01-02-2005, 10:20 PM   #3
kwmech
My burb with an auxillary cooler holds 10 qts.
kwmech is online now   Reply With Quote
Old 01-02-2005, 10:43 PM   #4
67pro-street
great. thanks for the help fellas.
Old 01-02-2005, 10:47 PM   #5
Longhorn Man
While kwmech is right (many will varry for some reason) it is not a good idea to go dumping 2 gallons into the filler and then start it...nor is firing it up with no fluid.
Old 01-02-2005, 11:32 PM   #6
superchevy
Got big-block?
superchevy's Avatar
My 700R with a trans cooler holds 10 quarts as well.
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
