![]() Join Date: Aug 2002
head scratcher need help!!!
I've got a real head scratcher going on here. I have a 71 Chevy truck with a key-off short to ground somewhere. I changed the battery and alternator, and it charges fine when running. I came out today, and she wouldn't crank. The battery was down to 4V. I hooked up my little charger a couple hours ago, and just checked it again - now it's down to 3.5V.
Jason |
smokinn
Not sure what the short might be but you could always use one of those battery disconnect devices until you can figure it out. You can also hook up a voltmeter and diconnect items one by one until the drain goes away. Do all you accessories work correctly like the fan horn lights wipers etc?
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
its all about the +6 inches
look in the FAQ, there is a good write up on how to locate your drain. (not a short to ground...that would make lots of sparks)
Asuming there has not been anything added lately (like a stereo system) I would syspect a bad alt or horn relay. The relay is a good quick check...reach under the dash and grab the little silver box right by the fuse panel...if it is hot, unplug it and charge up your battery. This is also asuming that your horn doesn't work. |
