Brake Drum Options-'70 K20
I need front drums for my 70 K20. Is there any sources or do I need to do a swap to a newer front end w/disc brakes. Any ideas? I am new to the site and have probably missed similar posts. Thanks
user # 2756
![]() Join Date: Jun 2001
First off- Welcome to the board.
Second- You'd probably be better off finding a 71 and up front axle and go with disc. I had a similar problem and found a used set of drums on the board here two years ago. But, when these give up the ghost I'm going disc also. You could just swap the knuckles out which would save you from having to pull the axle. You can not swap backing plates it has to be the whole steering knuckle out. The 73 and up fronts have a slightly larger u-joint so that would be preferred.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
