Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-03-2005, 03:44 AM   #1
Hot Rod Willy
No longer a Member
Hot Rod Willy's Avatar
Wanted: Edelbrock 1406 Carb, Comp Cams 280h Cam/lifters, Weiand or Edelbrock intake
Weiand STEALTH intake or Edelbrock Performer RPM intake
comp cams 280h cam and lifters
Edelbrock 600cmf carb part number 1406
lemme know if anyone has this stuff for sale =)
Hot Rod Willy is offline   Reply With Quote
Old 01-03-2005, 04:32 AM   #2
1972C10
1972C10's Avatar
Ive Got A 1405 Its Seen About 5 Months of Use 165$ Only Reason I Quit Running It Is I Switched To A 750DP
1972C10 is offline   Reply With Quote
Old 01-03-2005, 04:40 AM   #3
leastbay
hey i got a comp 280 magnum in my engine that im tearing apart right nowit has less than 5 thousand miles on it let me take it out and get the numbers off of it to verify first because the guy that had the truck before me put it in
leastbay is offline   Reply With Quote
Old 01-03-2005, 09:02 AM   #4
Hot Rod Willy
No longer a Member
1972 c10: price negotiable?
leastbay: please lemme know!
Old 01-03-2005, 11:13 AM   #5
454_72_4X4
454_72_4X4's Avatar
I might have a 1406 I might sell.
That's a lot of "mights"!
Let me check to see what is is for sure and I'll get back to ya.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-03-2005, 06:01 PM   #6
leastbay
i have the cam out trying to ID it
Old 01-03-2005, 06:04 PM   #7
leastbay
ok pal its the right one
here http://www.powerandperformancenews.c...&Store_Code=CC
12-212-2 it looks in great condition and the lifters look new i have them seperated how they were in the engine in case you use them they will be on the same lobes lemme know if you need pics i'll ship it to you for $60
Old 01-03-2005, 06:17 PM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
That doesn't matter it was run in a different engine. Using used cams isn't that good of an idea. Reusing lifters its a big no no in a different engine that in was broke in on. That cam and lifter set is matched to the engine it was broke in on. The wear pattern will be different in your engine there's no to that will wear the same.
I'm not trying to kill your deal just saying what is commonly known.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-03-2005, 06:30 PM   #9
leastbay
true about the lifters
Old 01-03-2005, 06:35 PM   #10
Hot Rod Willy
No longer a Member
so i cant use this set?
Old 01-03-2005, 06:38 PM   #11
454_72_4X4
454_72_4X4's Avatar
As long as you keep each lifter on the same cam lobe it was on before you shouldn't have any problems.
They don't wear a pattern to the block because they spin in the bore as they work up and down.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-03-2005, 06:55 PM   #12
MylilBowTie
Right turn Clyde
In your case I would get the cam if you want it and buy a new lifter set then break in the cam. Thats the best bet I see to come of it.
Old 01-03-2005, 08:22 PM   #13
benscool1
benscool1's Avatar
I've got a Weiand Stealth intake for you. How does $50 sound?
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 01-03-2005, 08:45 PM   #14
leastbay
Old 01-03-2005, 08:47 PM   #15
leastbay
Old 01-03-2005, 09:23 PM   #16
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I have a brand new Edelbrock RPM Airgap intake I might part with if my 305 is kaput. Interested in a some Vette aluminum valve covers?
gchemist is offline   Reply With Quote
Old 01-03-2005, 09:28 PM   #17
Gray Ghost
Gray Ghost's Avatar
Got a pic of the valve covers? I might be interested.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 01-03-2005, 10:48 PM   #18
Hot Rod Willy
No longer a Member
how much for covers ide like them yes
Old 01-03-2005, 11:46 PM   #19
MylilBowTie
Right turn Clyde
Have you also thought about the things the a bigger camshaft like that will need? Pushrods, valve springs, and things like that?
Old 01-06-2005, 04:48 AM   #20
1972C10
1972C10's Avatar
Thats Really The Best I Could Do I Paid Over 200 For It And Havent used It That Much I would be open to trades Got Anything Good?
Old 01-06-2005, 12:44 PM   #21
Hot Rod Willy
No longer a Member
no sorry =( had 305 motor but it sold
Old 01-06-2005, 01:24 PM   #22
454_72_4X4
454_72_4X4's Avatar
I just went and checked, mine's a 1405 too. Same as 1406 but with a manual choke.
I'd take $100 + sh for it.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-06-2005, 02:01 PM   #23
Hot Rod Willy
No longer a Member
sorry good deal but i gotta pass for right now
