Old 01-03-2005, 06:59 AM   #1
tmad
Wanted to buy!!!
I am in need of an Alt bracket for my 67 c10 2wd lwb! I need the one that does not require drilled and taped holes in the head! (I have none.) My alt is mounted on the drivers side above the power steering pump the old bracket mounted to the exhaust manifold but I have installed headers so It no longer works!! Any Help????? (I have the 283cid)
tmad is offline   Reply With Quote
Old 01-03-2005, 07:44 AM   #2
GMC AMI
GMC AMI's Avatar
If you can not find the factory brackets they have after market brackets for this very problem.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 01-03-2005, 12:54 PM   #3
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
Header brackets
25. shipped to your door. Chuck
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 01-03-2005, 01:03 PM   #4
cadiac
brackets
Say, -I have 2 brackets left over from a Hooker header set that I bet are what you are needing. Can send a pic if you want to see them. -steve
cadiac is offline   Reply With Quote
Old 01-03-2005, 03:25 PM   #5
tmad
Man I need a pic of this set-up. I cant seem to figure out what I need!!
Old 01-03-2005, 03:34 PM   #6
GMC AMI
GMC AMI's Avatar
Alt.
This is what I have, a complete set. I hope this helps.
Old 01-03-2005, 03:49 PM   #7
GMC AMI
GMC AMI's Avatar
Better description.
Header bolts go in bracket 1. Bracket 2 mates to bracket 1 as red lines indicate. Alt. large bolt goes in bracket 2 and bottom of alt. Bracket 3 hooks to water pump and slot is for top alt adjustment bolt.
Old 01-03-2005, 06:47 PM   #8
cadiac
The stuff mike Files has looks like what will work. I'm missing one from my hooker set, unless I can find it. What Mike shows less the sloted belt adjust arm is what my illustration shows. [Hooker paperwork] I'll scan it and post it. -Steve
Old 01-03-2005, 07:15 PM   #9
cadiac
pic of Hooker lit.
Give me your email and I'll send it that way. If I resize it again I don't think it'll be clear. Send it in a PM. -Steve
