Old 01-03-2005, 01:42 PM   #1
l8racer
l8racer's Avatar
Rear disks on a 65 ??
We are rebuilding a 65 SWB with a 468 BB and want to put disk brakes on the rear.
Speedway Motors makes a nice kit but it won't fit over the truck axle flanges.
Does anyone know of an inexpensive way or kit available?
Dennis
l8racer is offline   Reply With Quote
Old 01-03-2005, 01:49 PM   #2
rodnok1
rodnok1's Avatar
I bought a kit from GMCPauls that worked great, about the only thing I had to customize was the e brake and weld on some tabs for the flex brake lines. I have a 12 bolt truck axle in mine.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 01-04-2005, 07:03 AM   #3
Woogeroo
Post
http://www.tsmmfg.com/
here is a place I read about in 4 wheel and off road mag - anyhoo, check 'em out.
I have not used them myself.
-W
Woogeroo is offline   Reply With Quote
Old 01-04-2005, 12:12 PM   #4
l8racer
l8racer's Avatar
Woogeroo, thanks for the info.
I checked out the web site then called and talked with Skip.
He was very helpful...as a matter of fact, I ordered a kit from them.
I'll let you all know how it works.
Dennis
Old 01-05-2005, 08:44 AM   #5
Woogeroo
l8racer,
glad to help.
definitely let us know how it works out.
-W
Old 01-27-2005, 06:56 PM   #6
l8racer
l8racer's Avatar
Wink
I worked with Skip at TSM and ordered the rear disk brake swap kit.
It arrived quickly and bolted on like a dream. The drivers side backing plate flange was warped a litte but after straightening it on the housing (should read as...beating it with a big hammer!) all went well.
I feel like it was well worth the money spent.
Check them out at www.tsmmfg.com, I would buy from them again.
Dennis
