Old 01-03-2005, 06:26 PM   #1
todds3535
todds3535's Avatar
Thumping noise?!?
Wondering if anyone can help me out with this one...I have an '87 K5 Blazer that I bought about 8 months ago, when I first bought it I checked it out as much as I could and the 4 wheel drive seemed to work ok. I really havn't needed it until a couple weeks ago when we got dumped on with about 6-8 inches of snow. So I put it in 4 wheel and take off from a stop sign and get this loud thumping from what sounds like the right front passenger floorboard.
I first thought it was the wheel hopping, but I can't be sure.
After disengaging 4 wheel drive it went away and I brought the truck back home and checked it out, nothing seemed loose or anything. But I havn't driven it in 4 wheel since this happened.
Any help is appreciated and thanks in advance.
Todd
todds3535 is offline   Reply With Quote
Old 01-03-2005, 07:10 PM   #2
Mudder
Mudder's Avatar
If it has a lift on it the first thing I would check is the driveshaft. Could be the chain in the transfercase slipping. Does it stop making the noise after you get going? More info..... needed.
Mudder is offline   Reply With Quote
Old 01-03-2005, 07:13 PM   #3
clarkjw24
I like cheese
clarkjw24's Avatar
Either a bad ujoint or cv joint in you front drive shaft. If its got any lift the driveshaft prob should have been "clearance" around the cv ears for more angle. Your hearing the front drive shaft wobble or pop. Check the ujoints and the cv nuckle and that should fix you.
Cruiser: 1972 K5, 400/TH350/NP205, D44 and 12Bolt, 35 TSLs.
Trail rig: 86 K5, 350 TBI, SM465/NP205, 5.13s, 14ff locked, h1 beadlocks, 42" TSLs, 64" rears, 56" fronts, D60 locked, 35pline, drive flanges, crossover, hydro assist, OBA.
Tow rig: 2002 F350 PSD CC Dually FX4, chipped, cold air intake, BFGs
clarkjw24 is offline   Reply With Quote
Old 01-03-2005, 07:31 PM   #4
todds3535
todds3535's Avatar
Blazer is still stock, suspension, axles etc. But I did plan on lifting it this spring. ( I don't have a garage)
It does stop after I reach about 30mph. Seems like it is just from a stop, when I accelerate in 4wd I noticed it for the first time.
I bought it for $800, and I did plan on fixing it up for a daily driver. And maybe some 4 wheelin' on the weekends. It runs and drives great and the body is not beyond repair. Just hoping it isn't too expensive...I'm laid off right now and don't have a ton of money right now.
Old 01-03-2005, 07:40 PM   #5
LONGHAIR
It is most likely the front drive shaft (CV joint). It could be in the axle joints too...but usually when they get bad they go stiff. This will result in the steering wheel jerking.
LONGHAIR is offline   Reply With Quote
Old 01-03-2005, 08:05 PM   #6
todds3535
todds3535's Avatar
I'll check the cv and axle joints out tomorrow. And take a look at the driveshaft. My trouble is I live in a trailer park ( or Mobile Home community to be politically correct ) and my damn land lord gets pissed everytime I lift my hood to check my oil.
Help is greatly appreciated, you guys are great.
If you pass through the S.E. Mich area look me up and I'll buy y'all a cold one.
Old 01-04-2005, 12:05 AM   #7
Americanrider
Does it have the factory Auto-hubs? If so the tend to get gummed up and will sometimes slip out making a racket.
Americanrider is offline   Reply With Quote
Old 01-04-2005, 12:10 AM   #8
todds3535
todds3535's Avatar
rider,
Yea, it has the factory auto locs. Is there a way to prevent this slipping from happening?
Old 01-04-2005, 09:06 AM   #9
todds3535
todds3535's Avatar
I guess to assure they don't slip again, I'll replace the auto's w\ a set of Warn manuals when I do the lift in the spring.
Thanks for the help.
Old 01-04-2005, 09:07 AM   #10
Mudder
Mudder's Avatar
Even if the auto hubs arent your problem I would change them out with manual lockouts when you get back to work. I never trusted them.
Old 01-04-2005, 09:10 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
A friend of mine had a bad clunking noise in 4wd and it was because a PO had swapped the tranny/transfercase and used the original crossmember and the cv was hitting the crossmember.
You need to rotate the front driveshaft by hand w/ the front off the ground and see what kind of play you have.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-04-2005, 09:44 AM   #12
todds3535
todds3535's Avatar
Thanks a lot for the suggestions. Very much appreciated. I'll go over the whole thing in the spring when the weather breaks.
Just checked the weather, We have a severe weather advisory until Thursday afternoon with snowfall reaching 6-10" and then turning to sleet and freezing rain.
Old 01-04-2005, 10:36 AM   #13
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Ah, suck it up and go lay in the snow. It suppose to be 71 here today.
Old 01-04-2005, 11:34 AM   #14
todds3535
todds3535's Avatar
I'm not complaining, lived here all my life. I don't mind just snow, it's the sleet & freezing crap I can do without.
71 huh? Lucky you.
Have a good one.
