Old 01-03-2005, 08:28 PM   #1
tmad
question for motor guys
Can someone tell me what the sheet metal piece riveted to the underside of an intake manifold is for????
tmad is offline   Reply With Quote
Old 01-03-2005, 08:31 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
To shield the oil from splashing onto the hot exhaust gas passage built into the bottom of the intake.
Oil would quickly build up sludge and carbon if it hit the hot part.
If you remove the cover, you'll find tons of sludge under it that's seeped in over the years. The rivets can be removed by tapping carefully with a sharp little chisel. Be sure to reinstall it after you clean out from under it.
Old 01-03-2005, 08:40 PM   #3
tmad
Gee that even makes sense!! Thanks for the reply, I always wondeered I just never asked !!!!! Todd
Old 01-04-2005, 12:13 AM   #4
4x4Poet
If you remove the cover, you might as well hot tank it and the manifold. Best way to get all the sludge/buildup off both. The cover needs to be removed before hot tanking anyway. If you're learing of doing it yourself, most automotive machinists know how from experience. If they say they can save the rivets for reuse, they probably know what they're doing.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-04-2005, 12:31 AM   #5
incoma
incoma's Avatar
We always used sheet metal screws to reattach the pan. That way you could unscrew it when you cleaned it out again too. The rivets can will slide back out after re-inserted. Don't want anything bouncing around in your oil gallery!!
incoma is offline   Reply With Quote
Old 01-04-2005, 10:06 AM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
When my motor was rebuilt I had mine cleaned. NAPA told me it was packed full of carbon. I think I only paid 20 bucks for the cleaning and it was SOOO worth it. It made painting it much easier, cause I didn't have to clean it!!!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-04-2005, 10:23 AM   #7
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
67RedNeck "When my motor was rebuilt I had mine cleaned. NAPA told me it was packed full of carbon. I think I only paid 20 bucks for the cleaning and it was SOOO worth it. It made painting it much easier, cause I didn't have to clean it!!!"
NAPA cleans things? What do they have?
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-04-2005, 10:35 AM   #8
67ChevyRedneck
I just moved to greenville this summer, but the Napa near Columbia, SC on highway 302 had a machine shop on the side of it... it was part of the store, only one I've ever seen like it. They rebuilt engines and cleaned parts, resurfaced heads...etc. My uncle had his 350 cleaned and bored out there. They used some kind of chemical tank to clean my intake. It had to sit in it for like a day.
Jesse James
Project "On a Dime"
Old 01-04-2005, 11:04 AM   #9
jay6891
Car Knocker
jay6891's Avatar
the NAPA store here in Pine Bluff also has a machine shop built into it. One of the better ones around here. We are talking about a cast iron intake aren't we? I always heard you couldn't vat an aluminum part because it would melt.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 01-04-2005, 11:12 AM   #10
67ChevyRedneck
yup, cast iron.
Jesse James
Project "On a Dime"
Old 01-05-2005, 04:20 AM   #11
4x4Poet
Hot tank. Many machine shops now have a second "hot tank" setup with chemicals that won't harm aluminum or galvanized metal.
