Aluminum Intake ?
What do you guyd do to keep your aluminum intakes looking good over time? Any tricks your willing to share?
graphic designer
carb cleaner and a pressure washer, works for me. of course you know to cover the carb and protect the distributor.
Neat idea! Have you ever clear coated one?
I am having my intake powdercoated with a clear color. I hope it will keep the intake from looking dull over time.
Youth soon passes away, but immaturity can last a life time. |
#5 | |
Had I an alum intake, I probably would try using Durashine.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
I just used clear enamel spray paint after I bead blasted it. It works good for a year or two. I generally took my engines apart to build a new one after a year or so anyway so the time the paint lasted didn't matter to me much.
What is Durashine???
Durashine. The mfr url Durashine.com doesn't work for this dialup user. No matter. I've found Durashine at kmart, walmart, etc.
I wonder if POR15 engine enamel in aluminum would work. I suppose it would only be appropriate if you wanted to cover some unremoveable stain in the cast pits of the alum intake. Bare cast alum with no flaws is better if it's left unpainted (with pigments, that is). I wonder if POR15's Metal Mask would work. It is UV resistent. It's not a high heat paint, but it must be rated to 500ยบ like POR15 is. Maybe too little heat protection to be incontact with water/exhaust passages. It could and should be brushed on, preferably with a foam brush. Just wondering. ![]()
Watch out for your cornhole !
![]() Join Date: Jun 2003
Let me look, I have a picture of a clear powdercoated intake that's been run several years. I'll find and post it. It looks pretty good still.
Picture is blurry.
Was powdercoated about 10 years ago give or take, the new owner has not cleaned it that I can tell. It would look better if he'd clean it every once in a while.
Weekend Warrior
I just spray them with regular clear from the paint store - usually when i'm clearing a car or something.
POR also makes a clear finish that supposedly can be put on chrome and shiny stuff...wonder if that would work. if i don't feel like clearing them i usually just paint them the same color as the motor.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
![]() Join Date: Apr 2004
Black will dissipate the heat quicker! When into drag racing we almost always painted them black.
1968 Chevy 4x4 307 4 speed |
#13 |
Got big-block?
![]() Join Date: Jul 2000
powdercoat it.
I've run several powdercoated intakes...not clear, but aluminum finish or "almost chrome" they call it...with no discoloration whatsoever. Then again, I powdercoat everything...I hate cleaning polished aluminum, and powdercoating makes it so easy to clean. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
#14 |
Well I went with the High heat (1200f ) Then baked it for a few hours,it sure looks good now Ill let ya know in the spring how it holds up!!!! Thanks for all the input I think I will powdercoat the next one. Todd
