Old 01-03-2005, 10:38 PM   #1
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Awesome deal on 3/4 ton 4x4 AXLES!
Ok, so my buddy totalled his 86 K20 the other day, and he told me I could have the axles, rims, and tires off it for $200!! so i definitely think i'm going to go for it. But what i need to know, is how hard is it to convert a k10 to 3/4 ton? Would i have to get a new rear driveshaft? or is my 1/2 ton one OK?
And also... how bad would 4.10 gears be with 33" tires... i have 3.08's now and love being able to cruise 75-80 no problem. Will my truck even get going that fast with 4.10's? oh man this is a lot to think about, well i will snatch up those axles anyway, and if i dont use them, i'll throw them on the board for sale, so keep your eyes peeled... give me some advice, THANKS
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 01-03-2005, 11:01 PM   #2
Fry
I hated 3.08 with 33s. 4.10 is recommend with 33s by most charts and people.
When I swapped mine over it wasn't has much of a dramatic change as I thought it would be.
I'd go for it with that price.
Fry is offline   Reply With Quote
Old 01-03-2005, 11:16 PM   #3
soleeagle
soleeagle's Avatar
to be safe I would get the drive shafts from your buddy too.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 01-03-2005, 11:20 PM   #4
SanitysBane
what about the T-case?
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 01-03-2005, 11:21 PM   #5
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Yes, good idea, and i will definitely get the front one, but he had a long bed, and i have a shortbed so i do not believe they rear shafts are the same length
IS THE T-CASE DIFFERENT???
-NICK
Old 01-03-2005, 11:36 PM   #6
Fry
I converted my 75 blazer over to 3/4 ton. You need a conversion u-joint. Mine was #447 I believe. There are 2 kinds one for inner clips, one for outter.
Front shaft will bolt up.
U-bolts and brake fluid is all you need.
You should make sure the brakes are good, 14bolt FF brakes are exspensive. More worth it to do rear discs if they need work.
Also you have ralleys so I'm guess you have 15s and the wheels he has are probably 16 so are you going with new 33s, or does he have 33s?
If your buying new maybe go with 35s if you want low revs?
Old 01-03-2005, 11:43 PM   #7
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Yes thats exactly what i was thinking... he has 31"s now which would look plain slilly with 4" lift. So i think i wll get 35"s. Keep your eyes peeled because i dont really like the rims and they might show up for sale sometime soon.
-NICK
Old 01-03-2005, 11:45 PM   #8
Fry
what wheels are you planning on going with?
H2s are cheap aluminum 8 bolt wheels but in 17" varity. Just a thought.
Old 01-03-2005, 11:52 PM   #9
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
yeah tires for 17" wheels tend to run a bit expensive, plus im not a fan of teh H2 wheels. I was thinking possibly going for those ALCOA wheels from the 01+ 2500HD's
The wheels he has are AR Tailgunners... they are steel i belive
Dunlop Rover MT's.... verrrrry soft tire
-NICK
Old 01-04-2005, 12:36 AM   #10
cochino12
It followed me home?
cochino12's Avatar
I got my 305's (5) for my 17"s for only like $250 from an H2, I heard over on fsc.com you can go to a local H2 dealership and get BRAND NEW takoffs for like $200.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-04-2005, 01:49 AM   #11
1FaastC10
1FaastC10's Avatar
your front shaft will work, as the front axle is identical to the one that is in your truck now, with teh exception of the 8 lug outers and gears. the rear i believe you will need a conversion u joint for, but shouldnt have a problem with the stock driveshaft.
1FaastC10 is offline   Reply With Quote
Old 01-04-2005, 03:17 AM   #12
1972
Majician
1972's Avatar
The t-cases are the same.
Here is a calculator that you can use to find what rpm you run at now and then do it again with your new combo to see how it changes.
1972 is offline   Reply With Quote
Old 01-04-2005, 06:20 PM   #13
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
hey 1972, how do i know what to enter in that calculator, i dont know the transmission values to enter. I know the gear ratio and transfer case but thats it...
And just to make sure, 315/75's are about the same as 35's, correct?
-NICK
Old 01-04-2005, 06:32 PM   #14
1972
Majician
1972's Avatar
You can click the dot next to your transmission in the list to the right of the page, same way for your t-case, then it fills in the ratios automatically.
The 315/75-16 should be real close 35". Here is another calculator to play with. There is a metric to standard tire size calculator in it also.
