Does the frame touch the bumper?
This may sound like a stupid question but my truck is in pieces and i didnt notice when it was together.
Does the front of the frame suport the front bumper at all? The reason i ask is because i bought a front roll pan and im not sure i want to use it. It requires 2" of the frame to be cut off and im wondering if i dont like the looks of it if i can just reinstall the old bumper or if i'd be stuck with the rollpan unless i welded the frame pieces back on?? |
Resident Curmudgeon
![]() Join Date: Dec 1999
Yes it does.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
![]() Join Date: Nov 2004
There is an L shaped piece that bolts to the top of the frame, at the front, to the bumper and then the bolt below that bolts directly from the frame to the bumper, so you do need the very front of the fame.....then the two side supports bolt to the side of the frame, near the front. CPNE said it much simpler....
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#4 | |
Resident Curmudgeon
DOH!
If you have unbent frame horns, don't throw them away. Most are slightly bent from front end mistakes and don't line up with all the bumper holes, especially when you use a new bumper. I found a straight set on a junker and sawed them off in front of the core support bracket, then I bolted them to my front bumper along with the side supports so they wouldn't get lost. I'll use them to replace the bent ones on my gmc. My 70 chevy still has the bent ones, and the bumper isn't fun to take on and off.
bw 70 chev short/fleet:son's hotrod w/tickets to prove it 69 gmc short/step: project in pieces 87 chev short/step: still thinking about 2000 gmc xcab/step: daily driver |
