Hood Won't Pop-Up '72
My hood has never really "popped-up" when I release the hood latch the hood only comes up slightly. I have replaced the hinges, but not the hinge springs. What's the solution? I have thought of buying a sping that goes over the catch stud. Any suggestions???
Thanks ![]()
"If you choose not to decide . . . you still have made a choice." |
67-72 Addict!
I recently oiled my hinges everywhere and it made a huge difference with the hood popping up. Nice and smooth!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
its all about the +6 inches
Try n ew springs...yours are stretched out more likely than not
SKINNY TIRES RULE!
None of mine have ever popped up either. My '69 is hard to open because the grill is pushed back slightly and it is hard to get my fingers between it. I did find that some good lubrication on all the pivot points of the hinges really helps make it easier to lift and close.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
I saw a couple of trucks that had the spring on the stud and they looked factory. Don't know if they are or not but I put one on mine and it works great.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
graphic designer
had the same problem a few days ago, hood wouldnt pop, and it always is easy. turns out it was frozen
#7 | |
The oddest Todd around
I've been thinking of doing that myself. Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
I just got a spring from pic a part off a camaro and put it on the stud.
The fix on mine was to rotate the rear of the hinge downward putting more tension on the spring when closed. I have a '72 GMC with the emblems shaved off the hood, so there is nothing to grab to lift it. Have to reach thru the grille to push up if it isn't set right.
72 GMC K20, 454, TH350 00 GMC Yukon 66 Ford Bronco |
