Old 01-04-2005, 11:43 PM   #1
sactoC10
71 DELUX
sactoC10's Avatar
Won't start in PARK, only Neutral ???
OK, so as noted...truck was having some serious attitude with me today. Got in it, turned key, no clicking, but everything electrical worked (radio, lights, wipers, etc...), jiggled the auto shifter, tried again...nothing.
Thought it felt like it should work since I have not had any charging problems, didn't seem like the battery was dead. For the heck of it, I tried it in Neutral and it started right up. Repeated this a few times, no problem in Neutral, no starting in Park.
What is the deal with that and NOW WHAT DO I DO?
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 01-04-2005, 11:53 PM   #2
neonlarry
neonlarry's Avatar
Sounds to me like your neutral safety switch might be out of adjustment.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 01-04-2005, 11:55 PM   #3
Purs
Got Big Block?
Purs's Avatar
what he said....
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 01-04-2005, 11:55 PM   #4
jhow66
jhow66's Avatar
Adjust netural safety switch on steering column.(put shifter in park and slide switch toward pass. side until it will start in park.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-05-2005, 12:38 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The contacts in the switch could be burned up too. Not a very common problem, but it could be.
Old 01-05-2005, 03:59 AM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Don't bypass it like I did to mine. Because some day you will forget...leave it in drive get under the hood...start it remotely and then have to chase it around the yard trying to get in and turn it off before disaster strikes...LOL! I wish I had video of some of those stupid stunts!!!!!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-05-2005, 04:09 AM   #7
lofly'a
lofly'a's Avatar
i've done that before too stlookn, and you've gooten some very knowledgable and sound advice here sactoC10
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 01-05-2005, 11:29 AM   #8
sactoC10
71 DELUX
sactoC10's Avatar
back to jhow66/neonlarry...
OK, maybe explain this to me with one or two more details... Where is this switch, under the column? Pull it, push it? Makes sense, but I've not done this before.
Yes, good input from this board indeed and no I don't want to be chasing it anywhere if I can help it!
2003 FORD Escape
1998 Honda VTR1000
Old 01-05-2005, 11:39 AM   #9
spencra
This, is my BOOMSTICK!
spencra's Avatar
That happened to me when I was about 19. I was a tech working at a Goodyear. I pulled this old Nova into one of the bays, put it in park with the car running. I walked away from it and all of a sudden one of the mechanics was like "Hey Larry, your car's taking off!". That damn thing slipped into reverse and took off out of the garage. I'll tell you I never ran so fast in my life. I caught up to it opened the door, jumped in, and slammed on the brakes just before it was about to hit a row of cars. . I look back on that one every now and then and just laugh my butt off.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 01-05-2005, 11:57 AM   #10
stllookn
stllookn's Avatar
spencra, Good one! The first time it happened to me (only twice now...thank goodness) I was working on a used Dodge van I had just purchased trying to figure out why the it would not move in any gear (very dirty tranny filter). I was by myself, left it in gear (accidently) and walked in front of it, opened the hood and then went to my tool box. As I turned around I saw it lurch forward and smack the work bench denting the hood. I've got to tell you that I quit working for the evening because that was a very close call and made me become a much more cautious mechanic.
Old 01-05-2005, 01:16 PM   #11
jhow66
jhow66's Avatar
Yes, good input from this baord indeed and no I don't want to be chasing it anywhere if I can help it!
Switch is under dash on top of column. There are 2 small screws that hold switch to column. Lossen only enough so that switch will move. Then do as I said in 1st post. (switch will have 2 connections on it-one for start (purple wires) and one for backup lights (green wires) )
Old 01-05-2005, 02:08 PM   #12
sactoC10
71 DELUX
sactoC10's Avatar
great and thanks... I'll check back later tonight after taking a peek at this
2003 FORD Escape
1998 Honda VTR1000
