Old 05-16-2001, 12:35 AM   #1
racedvl
racedvl's Avatar
Question Spindle questions.
If I were to say buy a drop spindle for a 68, and buy a spindle for a 72, are they the same part # ? Is the part # the same from 73-87? The reason I ask is I wanna convert my truck to disk. I don't have the option of rolling a whole new crossmember from a 73-79 truck under mine. I do have however a complete spindle set from a 72 suburban w/ centerlink. And I also the same from a 79 Suburban. Now I have been told that all you have to do is use the proper year ball joints to do this. I have also been told that by someone that tried this that he had camber problems. Ones that he could not fix. That's why I wanna know if drop spindles are the same in those year spans. Thanks for any help.
http://hometown.aol.com/racedvl/racedvl69index.html
Crystal Lake IL. 30 Miles north of Chicago
racedvl is offline   Reply With Quote
Old 05-16-2001, 06:22 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Cool
Dunno know too much about your appplication.
the fellas over here www.chevytalk.com Some there might be able to help you.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-16-2001, 09:44 AM   #3
67_SS396
Post
I used a set of stock spindles I picked up at a local bone yard from a '75 (?) Blazer and went back and got the center link from a '76 truck. I then went to the parts store and got ball joints and tie rods for a '75 model truck. I also have the stock springs from a '65. I have no problems with camber etc... It only took the alignment shop roughly 30 min. to do the alignment and they had no problems with it. They barely shimmed it up to tell the truth. My tires wear like they should and I have had no problems. Good luck.
67 SHORT STEP 396/Powerglide, 3.73's All the normal go fast
goodies. Power discs and
power steering.
2000 Silverado
1998 Nissan Frontier
Have you beaten a F*rd Lately?
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 05-16-2001, 01:09 PM   #4
ImpalaSS
Post
im pretty dam sure that 67-70 71-72 and 73-87 drop spindles are all diffrent
www.xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
ImpalaSS is offline   Reply With Quote
Old 05-16-2001, 01:25 PM   #5
Low69CST
Post
I know that they are different.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, all stainless hard and flex lines, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims
See my truck at: <A HREF="http://www.geocities.com/low69cst/index.html
Future" TARGET=_blank>www.geocities.com/low69cst/index.html
Future</A> Automotive Engineer attending the University of Kentucky.
Feel free to message me on AOL, SN- SS95ZQ8
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 05-16-2001, 01:36 PM   #6
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Thumbs up
I used 73 spindles and changed upper balljoint and tie rod end. No prob. and aligned fine
68chevy with93stepside on bags tuckin 17's 97 Honda 900 RR 6 color change chameleon paint polished frame and wheels
95 Chevy Tahoe soon to be dropped 5in on 18's and pimped out
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 05-19-2001, 09:42 AM   #7
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
73-87 spindles will work on 71-72 but you need to get the correct ball joints and modify the a arms to accept the new ball joints.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 05-20-2001, 11:34 PM   #8
Fast68Chevy
Fast68Chevy's Avatar
Post
A arms are same, you dont have to modify the holes for the balljoints, asd the casings are all same, just the stud length and diameters changed.
From 72 to 73 only the upper b-joints are different.
-'77 Electra 403/TH350
-'76 GMC C-1500 Sierra Classic 350 4-bolt/TH350, 3.40 ratio
-'68 C-10 chassis
-'72 K-5 chassis
The designer of the #333882 head castings needs run over(edited) !!!
http://communities.msn.com/RandyR72K5
Randy
Lincoln, IL
"life's gonna leave me in the dust, if I don't try and catch up to it soon"
r72k5@hotmail.com
Fast68Chevy is offline   Reply With Quote
