01-05-2005, 01:18 AM | #1 |
Happy to be here
Sway bar and air dam????
I bought a sway bar from Buffalo Elk for my 77 Cheyenne. He delivered it to Stoked Out Specialties for me today. They held it up to my truck, and it looks like the air dam will have to be removed for the sway bar to fit.
Does any one have a front sway bar and the plastic air dam on their truck? I need some pics to see how this works....
01-05-2005, 01:36 AM | #2 |
mine had both the bar and the air dam when i bought it. i can't see why they would interfere. the airdam bolts to the bumper and the swaybar to the frame horns and lca's.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
01-05-2005, 01:40 AM | #3 |
i just looked at the pics of your truck and i have never seen an air damn like that. mabey its only on 73-80's, the 81-87 ones bolt to the bottum of the bumper
01-05-2005, 06:30 AM | #4 |
BAD BOW-Silverado XST
Look carefully and you can see the sway bar mounted on my truck. I don't see how it would not fit. |
01-05-2005, 09:52 AM | #5 |
Happy to be here
Ok, it looks like I need to be more specific about my request. Since it's a 77 the air dam is mounted behind the bumper. I need pics from someone with a 73-80 truck....
01-05-2005, 11:51 AM | #6 |
ROCKET POWER!
I have a swaybar+the hideous 73-80 airdam. Short of the swapped engine the truck has an amazing amount of factory issue parts (and all of them need to be replaced ).
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
01-05-2005, 01:29 PM | #7 |
Professional Grade
I'll snap some pictures when I head back to school and post them when I get home
My air dam is all busted up unfortunately =/
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-05-2005, 05:08 PM | #8 |
Anyone have pics of how the sway bar mounts? I got one on the way too and was wondering if I'm gonna have to drill the holes or should they be there? Its going on a '78 heavy half, I think he said the bar is from an 81 its a 1 1/16".
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
01-05-2005, 06:27 PM | #9 | |
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
01-05-2005, 06:47 PM | #10 | |
Insert Witty Text Here
It looks like N2TRUX is missing two of the bushing mounts. It should have 4. Two for the frame and two for the LCA. Go ahead and replace the bushings when you install it. I think they were $3.99 a pair at Auto Zone for poly bushings, so there is little expense involved. Oh, and adding the swaybar will make an amazing difference in how the truck handles. Slonaker |
01-05-2005, 08:10 PM | #11 | |
Happy to be here
bluex- Yes the 1/2 tons are 1 1/16" and the 3/4 tons are 1 1/25" which is what I have now. Slonaker- I have a complete bushing set with clamps from PST that I didn't use on my Blazer suspension rebuild. It's a 1 1/16" set so I don't know if I can make it work or not. If it won't I'll just buy new ones. |
01-05-2005, 09:05 PM | #12 |
67-72 parts collector,…
Not trying to jump topics,... But I have a "new" pre-'81 air dams if someone needs one. Just send me a PM.
01-05-2005, 10:24 PM | #13 |
[QUOTE=N2TRUX]Russell that would help a lot.
bluex- Yes the 1/2 tons are 1 1/16" and the 3/4 tons are 1 1/25" which is what I have now. I think it should be 1.25" ( 1 1/4") and not 1 1/25"
01-05-2005, 10:50 PM | #14 |
Professional Grade
Here we go!
Check out that tasty salt!! And yes, I know the bushing fell off the bar, my truck squeaks like crazy becuase of that, just been too lazy to put the bushing back on... The dam is gonna come off pretty quick, It is broken, and the tire rubs it when I turn sharply to the right.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 01-05-2005 at 11:09 PM. |
01-06-2005, 12:00 AM | #15 | |
Happy to be here
Russell-Thanks for the pics. Since I can't be where my truck is that helps a lot. From what the guys at Stoked Out were seeing, they felt sure the air dam had to be removed to clear the sway bar. It appears that looks are decieving ... Now get your bushing back in place.... Last edited by N2TRUX; 01-06-2005 at 12:06 AM. |
01-06-2005, 10:14 AM | #16 | |
Active Member
Just pm'd you. |
01-06-2005, 05:02 PM | #17 | |
It just so happens I'll need a set for my 1 1/16 bar if you want to sell them. Just LMK and I'll be glad to take them off your hands. So theres no brackets at the LCA other than the ones around the bushing, and two brackets that attach the bushing to the frame. Those two are coming with my bar but one is bent up, anyone have the part numbers for them handy?? Thanks for the help guys.
01-06-2005, 09:58 PM | #18 |
Pre-'81 air dam
Here's a pic of one, off the truck. I believe they are still available from GM. Also I think there use to be a 2wd,... AND a (taller) 4wd version.
01-07-2005, 11:04 PM | #19 |
Happy to be here
Ok, now I have a new question for an old thread. Does anyone know the answer to this-
I just read the thread that Tx Firefighter posted in the FAQ forum about Early Classics Front Sway Bar Frame Mount Brackets for lowered trucks. I went to Early Classics website and discovered they only make these to fit 63-66 and 67-72 trucks. I know you can put a 73-87 crossmember under a 67-72 frame so I "assume" the sway bar mounts are the same too. Can anyone verify this to be true? Has anyone used a 73-87 sway bar set up on their 67-72 frame? |
01-07-2005, 11:30 PM | #20 |
yes
N2TRUX,... I had the ECE mounts on my old '82 2wd Blazer. I had ordered them for my '71 swb project,... but decided to use them when I lowered the blazer front end. Sorry, but I don't have any pics.
01-07-2005, 11:33 PM | #21 |
Happy to be here
lolife99 that's what I needed to know. I "assumed" they would work just fine, but I wanted to be sure before I ordered a set. Thanks for the info....
BTW- Do you have "any" pics of your 82? |
01-07-2005, 11:36 PM | #22 |
Watch out for your cornhole !
Those two grease zerks pointed straight down look like they are going to be in serious danger of getting whacked off on the first thing that hits them.
01-09-2005, 12:06 AM | #23 |
Pics for N2TRUX,...
I had to scan some crappy old photos. This is all I have. The pics make it look better than it actually was. It needed rockers, quarters, and more power under the hood. Still made a nice beater. Sold it for $3400.00. Kinda wish I had it back!
01-09-2005, 12:24 AM | #24 |
Ken,... I almost for got. CONGRATS on the magazine feature! I will have to add that one to my collection. lolife99.
01-09-2005, 12:44 AM | #25 | |
Happy to be here
The red paint does hide a lot. The pics make your Blazer look great. I bet you do wish you had it back, but you still have another sweet Blazer. I cleaned your pics up for you.... |
