01-05-2005, 05:31 PM | #1 |
standard brakes to power
Is there much work to convert standard brakes to power brakes, I'm thinking if there isn'y much to it I'd like to do it, (safety) thanks marvxyz
01-05-2005, 05:32 PM | #2 |
The brake conversion would be on a 80 GMC
01-05-2005, 07:20 PM | #3 |
I believe you will need a new master cylinder, a brake booster, and you will need a direct vaccum from the intake. Hope this helps.
01-07-2005, 06:55 PM | #4 |
Thanks poink71 chev, but where would i pick up direct vasccum from the intake.
marvxyz |
01-07-2005, 10:36 PM | #5 |
most I have seen have a plug behind the carb in the intake or on the bottom of the carb.
