Old 01-05-2005, 11:02 PM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Stupid Guy w/ an HEI
Alright, heres the story. I am putting a new 290hp Chevy long block in my 1972 C-10. I ordered an HEI through Jegs and I cannot figure out what I have or if it is even usable for my truck. On the new distributor I have the cap and rotor and on the side I have a wiring harness with a Black,Red ,and a Brown wire sticking out by thr vacuum advance. That is the only wiring coming out of the side. Where am I supposed to hook the power to? Does it go to the coil? All I have is the yellow and red with the pins and the black with the lugs. I have looked at all the previous post and cannot find the answer.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 01-05-2005, 11:13 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Those 3 wires plug into the distributor cap.
Then, you plug the 12v power wire to the cap also. It should be labeled on the cap where to plug the 12v if you look closely.
Old 01-05-2005, 11:35 PM   #3
jhow66
jhow66's Avatar
See if this helps:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-06-2005, 11:05 AM   #4
Dick Dale
Dick Dale's Avatar
Thank you for thje help. Does it ever seem as if the easy stuff seems like f**king rocket science sometimes?
Budget 350 Build
