Old 01-06-2005, 07:16 AM   #1
Don Meyer
where to put battery
I have a 2 post lift & the battery holder att to the frame prevents me from using the lift.
Should I put the battery on the firewall or behind the seat? Will there be a problem w/fumes with it in the cab? .......Don
Don Meyer is offline   Reply With Quote
Old 01-06-2005, 09:51 PM   #2
Don Meyer
knock,knock - can anyone give me their thoughts.
Dr Don
Old 01-06-2005, 11:43 PM   #3
Apache
Apache's Avatar
If you are moving the battery id go with putting it on the firewall. Be much safer IMO. Fumes would be in the cab...im sure not that bad but still could be a safety hazzard. Very interesting truck btw.
54 Chevy Bel Air 4dr powerglide
54 Chevy SWB
58 Chevy Big Window SWB Fleetside project
58 Chevy LWB 235/4spd
76 Chevy Nova 350/TH350 4.88's *10kmiles on "new" engine
79 Chevy 4x4 SWB 350/4spd 3/4 ton
81 Mazda RX7
84 F@!d Mustang
96 F@!d Ranger 2.3L/5spd
Apache is offline   Reply With Quote
Old 01-07-2005, 09:13 PM   #4
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
put it up inside the frame & run 00 wire for cables. cleans up the firewall & put the weight farther back.. &&&&&&&& damn Don that baby come'n along. is that a late model bed w/what early 60's caddy fins????..joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 01-08-2005, 08:27 AM   #5
Don Meyer
Yes Joe. It has a late bed narrowed 13". The fenders have been narrowed 5"(not installed yet) w/Caddy fins.
Top chopped 3 1/2",doors,cab & frame lencthened 3". 350 engine/700r4/9" rear.
Thanks for your comment.....Don
Old 01-09-2005, 11:43 AM   #6
3100 special
Street Rod Dreamin'
3100 special's Avatar
Location: Work:Batam, Indonesia/ Home:League City, Texas
I'm with TooMany2count. I definitely would not put it in the cab.
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2007 GMC Sierra 4X4
"I am for doing good to the poor, but I differ in opinion of the means. I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it."
Benjamin Franklin, On the Price of Corn and Management of the Poor, November 1776
3100 special is offline   Reply With Quote
Old 01-09-2005, 10:09 PM   #7
Don Meyer
What about a Optima battery in the cab?
Old 01-10-2005, 12:25 AM   #8
TooMany2count
well IF ya can find a place it will work. but WHY??? unless ya just got to have it in there. you could also make a box & put it inside the rear/bottom part of the front fender hanging off the frame. Personally i dont like them inside, even if it is a sealed battery, IT just takes up space.
BUT hey don if ya can find a place & ur happy w/it go 4 it....joe
My Music PlayList
Large Marge
Old 01-10-2005, 12:37 AM   #9
3100 special
Street Rod Dreamin'
Even sealed batteries have vents. The vents will emit fumes.
Fumes are bad for ya.
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 01-10-2005, 08:02 PM   #10
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Truck looks cool.What kind of suspension is under the front?I would prolly go with the firewall only because I woldn't want it in the cab either.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 01-11-2005, 08:52 PM   #11
horvath
horvath's Avatar
OPTIMA batteries don't emit fumes.
Alan Horvath
54 Chevy Pickup
horvath is offline   Reply With Quote
Old 01-11-2005, 08:57 PM   #12
Don Meyer
Horvath, Thats the info I was looking for......thak-you.
Don
Old 01-11-2005, 09:00 PM   #13
horvath
horvath's Avatar
Cool.
You can install 'em sideways if you want, too! I had to enlarge my battery holder (on the frame) to put one in, but I'm glad to have one. I bought the Red Top Optima.
Alan Horvath
54 Chevy Pickup
Old 01-11-2005, 09:30 PM   #14
Brainchild
Brainchild's Avatar
I had a dickens of a time finding one that would fit in the floorboard.90 Caravan was the answer.
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 01-11-2005, 10:22 PM   #15
3100 special
Street Rod Dreamin'
How can that be? Anything that gets hot expands. If it didn't have a method to vent the pressure resulting from heat then it would conceivably blow. Wouldn't it, at a minimum, have some type of safety gasket that would "let go" when a specific pressure was built?
I haven't read up on the Optima batteries yet but, I know they are supposed to be really good.
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 01-12-2005, 12:35 AM   #16
TooMany2count
well you are correct YET you are also wrong. from the Optima Battery site
http://www.1st-optima-batteries.com/battery_specs_1.asp
The D31A Yellow Top will not off-gas in normal operation, but for complete safety in enclosed spaces its overpressure vent will accept a remote venting tube.
SOOOOO it could possible happen, but the likely hood is slim. my own advice is IF you install it inside VENT it, better safe then sorry....joe
My Music PlayList
Large Marge
Old 01-12-2005, 01:02 AM   #17
3100 special
Street Rod Dreamin'
I can live with being half-a$$ right!
2004 GMC Yukon
2007 GMC Sierra 4X4
Old 01-12-2005, 01:55 AM   #18
TooMany2count
hell i wasnt paying attenion that horvath bought a RED top battery. so once againg from the site & ain't it amazing what a person can find on the internet.
http://www.1st-optima-batteries.com/...tery.aspOptima batteries will operate without leakage when mounted in any position, and they do not off-gas in normal (<~~read this) operation. That means that corrosion at the battery cable connections and elsewhere under the hood (<~~once again read) which is normally caused by drifting acid fumes, is eliminated.
what concerns me is WHAT determines NORMAL once again if it was ME & the battery was INSIDE the truck, i would at least make sure the battery box is completely sealed & is vented to the outside................ it's call Cheap Insurance ....joe
My Music PlayList
Large Marge
Old 01-14-2005, 10:55 PM   #19
Don Meyer
Thanksfor all the suggestions. I have decided to place the battery in the bed.I'll made a ss box & cut a opening in the floor of the bed & lower the battery as low as I can....just below the floor if possigle.
For the gentleman who asked what front end I'm using.....it's a 1986 buick regal(same as a malibu.
Don
Old 01-14-2005, 11:05 PM   #20
horvath
horvath's Avatar
That sounds like a GREAT solution, man!
Alan Horvath
54 Chevy Pickup
