07-11-2001, 11:30 AM | #1 |
Not happy with a 3/5 drop, any suggestions ?
I have a 67 C10. I replaced the springs and shocks with drop springs and drop shocks.
I chose a 3/5 drop cause the sales people said with a 6 inch drop in the rear I would have to notch the frame. I got several replies from people out here that had a 6" rear drop and were fine. I should of went with the 6" drop in the rear. My question is, if I go with lowering blocks, I have rear coils, will it warp the axles, or give me wheel hop. I was reading that lowering blocks were not a good choice for lowering. I would like to lower the back about another inch a half. Without cutting the new spring, or replacing the lowered shock. Any suggestions? Thank you. |
07-11-2001, 01:23 PM | #2 |
SLICER AND DICIER
nothing wrong with blocks as long as you don't go bigger than 2in. Whoever said that must have been smokin somthing, or they installed them wrong which is not the blocks fault just the BLOCKHEAD.
------------------ 68chevy with93stepside on bags tuckin 17's 97 Honda 900 RR 6 color change chameleon paint polished frame and wheels 95 Tahoe dropped 4in on 18in Niche's.
01 Tahoe 22's 2/4 drop and tv's 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
07-13-2001, 11:09 AM | #3 |
Lowering blocks work great, but as a suggestion, I would have some built that are angled. As you have already dropped a long way with coils, The pinion angle of the rear axle is way out of wack compared to the output of the transmission (or steady bearing). You may get a vibration, or wheelhop, or it just may wear out U joints quicker. What you want is a block that when installed returns the pinion angle to close to stock. Try one of the suppliers that advertise in these pages. Also, you may need an adjustable track bar to re-center the rear end under the truck.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now). 95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver |
07-22-2001, 07:24 PM | #4 |
aka Crusher, Crushergmc
Yep, wooden blocks will give you wheel hop! LOL. The angle suggestion is right on.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
05-31-2011, 05:30 PM | #5 |
Just a car guy
Re: Not happy with a 3/5 drop, any suggestions ?
Are you going to take tbd front lower?
I installed 3/5 springs, and my front looks a little higher, maybe 1/4". I was thinking about adding drop spindles to the front to get the rake back. Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
05-31-2011, 05:31 PM | #6 |
Just a car guy
Pick of mine,
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig Last edited by OJ1988; 05-31-2011 at 05:32 PM. |
05-31-2011, 09:07 PM | #7 |
Happy to be here
You can go with 1.5" blocks if you are running 15" wheels. Larger wheels will allow for a 2" block with out scrubline concerns.
05-31-2011, 10:37 PM | #8 |
^^here
I would just add a simple 1-1.5" block to your setup, a very inexpensive and worthwhile lowering method for these trucks in the rear. The nice thing about it is, if you have anykind of fab skills you can modify the block to the "exact" drop you need/desire. |
06-01-2011, 12:23 AM | #9 |
I do believe this is the dustiest thread I've ever witnessed on this site. Almost 10yrs....
06-01-2011, 12:46 AM | #10 |
I wonder if he got blocks.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 06-01-2011 at 12:46 AM. |
06-01-2011, 07:19 AM | #11 |
Just a car guy
Well, you know what everyone says, "search before you post"
so I searched Posted via Mobile Device
06-01-2011, 08:51 AM | #12 | |
Happy to be here
Now on to your question. I prefer to get as much drop from spindles as possible. A 3" spindle may require some mods to the A-arm, but it doesn't affect the ride quality. If you want more then trim the stock spring till your happy.
06-01-2011, 09:09 AM | #13 |
Not criticizing; just commenting on the gap between the last post & yours. I've seen some that were 3yrs, maybe even 5-6yrs..... never anything longer.
06-01-2011, 10:14 AM | #14 |
Junior Member
I think its awesome he was taking the time to search and educate himself on the subject first.... two thumbs up!
06-01-2011, 10:18 AM | #15 |
Agreed.
06-01-2011, 12:22 PM | #16 |
Yellow truck club
back shelf find behind the preserves......
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
