Old 01-06-2005, 10:35 PM   #1
70 GMC 4x4
questions on np 205
Right now I have a turbo 350 and a np 203. I would like to change out the np 203 for the np 205 that I have in the garage. Will my turbo 350 bolt up to the np 205 with the correct adaptor? Is there two different styles of 350's? Short or Long shaft? I am also looking for the shifter that would go with the np 205.
Also what is involved in rebuilding a np 205? It has been sitting a while.
Thanks,
70 3/4 GMC 4x4, 400sb
70 GMC 4x4 is offline   Reply With Quote
Old 01-06-2005, 10:48 PM   #2
kwmech
There is only 1 output shaft on the 4x turbo 350, so yes with the correct adaptor it will bolt right up. You will have to redo the rear drive shaft.
Old 01-06-2005, 10:54 PM   #3
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Thanks,
But yes if I am not wrong, I do believe there are two different output shaft housings on the TH350's. Oh and on the NP205 question, I have a issue of peterson's 4 wheel that they rebuilt one and it doesn't look to hard. If ya want I can take a pic of the pages and post them on here or send them to you. Oh and don't worry about pic quality, My cannon digicam is very high quality...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 01-06-2005, 10:59 PM   #4
70 GMC 4x4
thanks for the info. If I rebuild it I have access to the book you are talking about, thanks though.
Old 01-06-2005, 11:01 PM   #5
turkeyguide
Get yourself a Chilton manual. It will show a complete breakdown of the 205 and 203 and make rebuilding easy. There is not much that should need work. The 205 is supposed to be tough.
turkeyguide is offline   Reply With Quote
Old 01-06-2005, 11:02 PM   #6
784X4GUY
784X4GUY's Avatar
Yeah not a prob man, take it easy and good luck...Later Mike
Old 01-06-2005, 11:38 PM   #7
kwmech
It is the 203 that is tough--I think it has about half a kabillion needle bearings in it.
Old 01-07-2005, 12:03 AM   #8
soleeagle
soleeagle's Avatar
the NP203 is chain driven and the NP205 is gear driven which makes it the better one out of the 2. The chains get slack and slop in them and become weak.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 01-07-2005, 12:47 AM   #9
72 CustomCamper
huh ???
72 CustomCamper's Avatar
This site should help rebuilding the 205...
Chuck
http://bulldogs-house.com/Projects/np205/
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-07-2005, 02:27 AM   #10
4x4Poet
Great writeup, 72CustomCamper. Thanks. Now to figure out enabling javascript on my PowerbookG4.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 01-07-2005, 05:15 AM   #11
LKJR
no body answered your shifter question that I saw
If your not resotring this truck, I'd skip the who HA of messing with the stock shifter. Since your looking at rebuilding the unit anyway just go ahead and do a twin stick conversion on it. You'll thank yourself later. Much easier to shift, Lot less headache later if you change your mind and decided you wanted it.
the case is apart, you need a shifter, no real excuse.
1st Gen Blazers
Like em big and topless
LKJR is offline   Reply With Quote
Old 01-07-2005, 08:16 AM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Has your 203 been converted to part time operation? I believe the you'll need the correct adapter and output shaft for the turbo 350, Can you find a 350/205 combo for sell in your area might be easier to do, then sell the 350/203 and your extra 205, just a thought.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-07-2005, 12:52 PM   #13
poff
205s came with two or three spline counts. 10 spline for a 4 speed will not bolt up. TH400 may have had a different spline count as well.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 01-07-2005, 02:17 PM   #14
MAC67
" SHOW ME"
MAC67's Avatar
yeah if i remeber right , your th400 205 is a 27 spline input sharft , the 4 spd 205 has a 10 spline input and the th350 is a 32 spline input shaft , you will need to cound the splines to see which one it is obvious if its a 4spd tranny , ive got a th350 to a 205 adapter but you will have to make sure the input shaft on your 205 is 32 spline , wish they woulda made em all the same ,
MAC67 is offline   Reply With Quote
Old 01-07-2005, 05:17 PM   #15
plumbcut
california fill
everybody is givin you good info- but mac67 you must be a little dyslexic the th350 is 27 spline and the finer spline count is for the th400...
Chuck- thanks for posting that link, thats one of the best writeups ive ever seen, for ANYTHING.. . Ive been thru the 205 but its been a couple years and I wasnt as thorough as that guy was... Im needing to go thru it again because something got chewed up in mine, and boy that writeup will come in handy.. makes me wanna go tear into it right now!
pc
plumbcut is offline   Reply With Quote
Old 01-07-2005, 06:42 PM   #16
70 GMC 4x4
Yep, I have a 10 spline np 205. I guess I will have to find a 32 spline 205 sometime.
Thanks alot for the info. Thank goodness I did not tear the truck apart yet!
Thanks,
TIm
Old 01-07-2005, 08:43 PM   #17
poff
If you are going to rebuild it, you can change the input shaft.
Old 01-07-2005, 10:30 PM   #18
kwmech
Thanks,
TIm
You need the 27 spline not a 32. The 27 spline is a direct swap of the gear with the same bearing. the 32 spline input requires a 210n bearing which is about another 1/4'' in diameter an requires the case to be machined. The 32 spline is for the turbo 400.
Old 01-07-2005, 10:53 PM   #19
70 GMC 4x4
Is it hard to swap the out put shaft? How expensive is it?
Thanks,
Old 01-08-2005, 01:34 AM   #20
kwmech
You need to swap the INPUT shaft of the 205 case to a 27 spline. Because of the size of the gear it has to come out the back of the case. I cannot remember how many I have done so it is easy for me. With a little patience I'm sure you could do it. Not really that hard. Probably the hardest thing would be the pocket bearing needles between the input and output gears. 17 of them I think. A brand new gear and a new bearing may run you about 175. COMPLETE gasket and seal kit--about 40 to 50.00
