Old 01-07-2005, 08:31 PM   #1
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
front end
i am ready to start putting things back together on my stepper and thought before I bust my hump restoring I could get some help. Does anyone know of a place to get the spindles, brakes, calipers, pads and lines that is not going to kill me, even if I have to go stock, just not 1,200.00 dollars. thanks.
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 01-07-2005, 09:17 PM   #2
C&C Chevy
C&C Chevy's Avatar
Lowering or not? It'll probably be just as cheap, if not cheaper, to just get some drop spindles.
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 01-07-2005, 09:43 PM   #3
AspecialZ
AspecialZ's Avatar
hmmmmmmm
the problem with that is that someone already lowered it, but all they did was cut the springs, I'm not sure what to do because I don't know who messed with it (the truck) this is a pic of it's height now, maybe you can tell...
Old 01-07-2005, 10:07 PM   #4
TIMSPEED
TIMSPEED's Avatar
DJM 3" Drop Spindles = $250
Summit 2" Drop Springs = $90
New Rotors from Local Parts Store = $100
Get calipers from local junkyard = $50
SS Braided Brake Lines = $100
New Brake Pads from Local Parts Store = $25
$600, done deal. Probably not gonna get much cheaper than that.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 01-07-2005, 10:22 PM   #5
RockHQ
ROCKET POWER!
RockHQ's Avatar
i would seriously recommend new calipers and rubber brake hoses over SS brake hoses and junkyard calipers. When redoing brakes, used is NOT the way to go.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 01-07-2005, 10:40 PM   #6
TIMSPEED
TIMSPEED's Avatar
Sorry, I should have states, get used calipers, while getting all the "guts" new.
See Them Here
Old 01-07-2005, 10:56 PM   #7
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Good luck with all of it TIMSPEED...Later Mike
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 01-08-2005, 08:20 AM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
30.00 And you can have get a good set (both sides) of remanufactured calipers from KOI, Savage auto parts. It has everything for the caliper (mounting bolts, copper washers, brake pad clip) minus brake lines and pads. Brake pads I got were Raybestos PG Plus 80.00 and new Raybestos rotors 1.25 thick thinking 80.00 also for the pair. Raybestos rubber brake lines was roughly 40 for the pair. I cant find my slip when I bought all these parts to get the exact price.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 01-08-2005, 10:27 PM   #9
C&C Chevy
C&C Chevy's Avatar
I would get some new springs. You can get some ACDelco springs for $80. RockAuto.com has them. Or keep an eye out on Ebay. I've seen them there before. I wouldn't go to the bother of rebuilding a front-end to just put the cut springs back on.
Robert
Current:
Past:
Old 01-08-2005, 10:33 PM   #10
TIMSPEED
TIMSPEED's Avatar
Summit's 2" Drop Springs are $87...
ASpecialZ,
See, it's not that expensive to get all the stuff replaced
See Them Here
