Old 01-08-2005, 10:18 AM   #1
smokinn
smokinn's Avatar
air compressor
I'm in the market for a new air compressors. I don't know anything about them, except that I should buy one that the main thing to look at is the SCFM delivery. Does tank size mean anything? or do i worry about how much cfm it produces?
jason
smokinn is offline   Reply With Quote
Old 01-08-2005, 11:18 AM   #2
Mike76251
One thing to NOT look at is the HP rating.
Ever see a real industrial 5hp motor?
If you do and them see a 5hp motor on a compressor you get from Sears or Lowes you will know what I mean.
First thing I would do is look at the CFM needs of any tools you might hook up now or in the future.
I like to guage a compressor against a straight line body file or a good paint spray gun.....if the compressor can handle those tools (with 20% reserve) then it will probably do.
Mike76251 is offline   Reply With Quote
Old 01-09-2005, 07:51 AM   #3
AirMale
AirMale's Avatar
I bought a Campbell Hausfeld 60 gal 6hp for $429 at Lowes. It handles everything I can throw at it. I have not done any sand blasting with it yet but I believe that is the true test of any compresor.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 01-09-2005, 07:53 AM   #4
Mike76251
Yeah...........I forgot about the sandblast gun......that will tell alot
Old 01-09-2005, 04:44 PM   #5
83shorty
these are good compressors. buy the best compressor you can afford.stay away from the craftsman oiless ones. they are NOT for people who use a lot of air. i had one and it took a dump on me. i was shocked at how cheap it was when i took it apart. live and learn. a 60 gallon stand up will serve your every need.
83shorty is offline   Reply With Quote
Old 01-10-2005, 12:38 PM   #6
454_72_4X4
454_72_4X4's Avatar
I'd second that completely. Mine was a 6hp v-twin and it had a bushing about 1/8 wide that held the ball bearing rod bearing.
Engineered failure point I called it.
A good 60 gal will do for probably 90% of individuals.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-10-2005, 09:33 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I have this light industrial compressor at home. Works great. I have not put it to a good test just yet. I will though once I start to tear up the front end.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
